Tom's Hardware > Forum > Games General > PC Gaming > New PC - graphics problem
Forum Games General : PC Gaming - New PC - graphics problem
Just spent £1,400 on a new PC as I've been getting into PC gaming a lot and my old 3.4Ghz HT Pentium 4 with 1GB PC3200 RAM and 256MB X600 Pro graphics card were struggling.
So my new system, from Dell, is specced:
E6600 (2.4Ghz) Intel Core 2 Duo Processor
2GB DDR2 PC5300 RAM @ 667Mhz
nVidia GeForce 7950GX2 with 2 x 512MB graphics card
320GB hard drive
My main game I wanted it for was Pro Evo Soccer 6, which my old PC stuggled a bit with, even at Med quality and 800x600.
My new PC runs it full-speed, no frame rate issues/slow down, even at 128x1024, High quality.
I can also run Need For Speed Carbon at full quality and Splinter Cell Double Agent.
However I have 1 problem, and it's one I never seen on my old PC, and it's very very hard to explain:
All the games so far seem to exhibit a strange "line" - I put "line" in quotes cos it's not really a line as such - the best way I can describe it is imagine a screenshot of a game. Now take the bottom 1/3rd of the screenshot and shift it, say, 10 or 20 pixels to to the right or left (in other words so the top bit of the pic is unaligned with the bottom) - this would give the appearance of a noticeable "line" where the "join" is (another example would be imagine hanging wallpaper and not getting 2 sheets perfectly aligned).
Now imagine this not in a static screenshot, but in-game, while things are moving. This is what I'm getting. It's not totally noticeable at all times, but it's enough to be annoying, especially when I've just spent £1,400 on a system to play games!
Sorry for sounding so vague, I might try get a video put together so you can see.
Cheers for any advice.
Sponsored Links
Have you enabled Vsync in games that allow it? It is called "tearing" and happens when your FPS are out of line with your refresh rate.
Do you have an LCD or CRT monitor?
Reply to tool_462
It's a 19" flat panel, and I'm looking right now in the nVidia Control Panel for a way to turn Wait for Vsync on, as some of my games don't have an option for it (Pro Evo Soccer 6 doesn't).
Reply to markmcrobie
lol you upgraded to play pro evolution soccer?
Reply to scarslilpyro
- 0 +
Some people have more money than sense. Did no one tell you op that your system was fine except your gfx card was muck? Switching that out for a £150ish x1800xt or similar would have been a supremely better way to spend your money????
I know a guy who bought an x1900xt to enable him to play Eve Online........
OP. There usually is an option to force enable vsync or failing that force a high level of AF and AA which should bring your frames down enough to stop tearing if that's what is happening.
Also put your monitor refresh to it's highest level and make sure your running the monitor at it's native res which should also help keep frames down.
Btw just to confirm you only get the "tearing" of the picture when it's moving and ONLY in games? It should be particularly noticable with vertical lines say on a building etc. If you get this glitch when the picture is stationary or outside of games, say when watching a movie, then you have another problem.
Reply to Wolfy
Only in games, yes.
What's so bad about my gfx card?
Nothings bad about it, he was saying your old one was guff and that the rest of your old system was fine and that you wasted almost all your money to play a simple football game on a monitor you would have been best of upgrading instead.
You wasted a lot of my I am sorry to say, something you will have to live with… it’s not even DirectX 10 compatible which it could have been in this timeframe if you shown a bit more wisdom and actually asked people what you should buy.
Reply to cafuddled
- 0 +
For the love of God stop buying Dell's for gaming.
Reply to PC_God
Dells are for family's, not gamers.
(Get a dell if your dad surfs the web, not to game)
If you want to build a custom, just pick out all the parts, and have someone else consolidate it for you if you are afraid of damaging parts.
Or, for instance, compusa has an extended warranty you can purchase that says if the part breaks, for any reason, even if you overclock it, you can take it back for the full price you paid, of coarse you will lose the warranty price.
That doesn't explain *why* not get a Dell for gaming.
- 0 +
Because, altho not always, you can pay more money for inferior stuff in comparison to buying the parts seperately off the net.
Furthermore when you ring good old Dell they'll usually do their best to sell you something expensive. Nothing wrong with this as they are a company trying to make money but for people who don't know any better then it can sting the pocket.
But regardless of all this, enjoy your pc but as a piece of advice the next time you reckon you need a new pc to play a game then post up your specs in the hardware section of this forum and someone will advise you on your best course of action.
Reply to Wolfy
To be honest the new PC is superb, and not just for gaming. I can now convert an avi to DVD with NeroVision in 20 mins instead of 1h 40m.
Also I now have a pukka copy of Windows XP, previously I had an illegal copy (only because my old had a genuine copy, but the motherboard died and I replaced it, and Microsoft told me my old key would no longer work as it was on OEM key and since I changed the motherboard I'd need to buy a whole new copy of Windows).
Also my new PC comes with a free upgrade to Vista Premium when released, which I'd have bought anyway.
I also got £440 by selling my old PC in parts on eBay.
Well if your happy that’s all that really matters, but really next time you want to upgrade go ask someone as to what you should get… oh another reason for not getting dell is you might find that little dell box you have there rather hard to upgrade in the future if you need to change or add something…
Reply to cafuddled
There are 1391 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
