I just purchased a MSI KT333 Ultra ASU, when I load up it starts an IDE scan and when its done it says "No Array is Defined". It says to shift+F to enter Fastbuild Utility and when I do it says "No Disk is found. Please check power and Data cable". Now this is confusing because it reads the Hard drive and cd rom now but it gives me this error. I am now able to access the windows XP installation disc, so should I just format and install now or should I try to fix this "No array" thing?
Is it normal when installing a new motherboard onto a computer that already has a hard drive loaded with windows to get a blue error screen?
Sponsored Links
do you have the hard drives plugged into the RAID controller IDE ports? Also, it's not advisable to put optical devices on the RAID controller. Keep the CD on IDE1 or IDE2
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
I am not using the RAID ports at all just the standard IDE.
Reply to DeViLgunner
thats why it's saying "no array defined" and not finding drives. You 've got to be connected to IDE3 and IDE4 to use the RAID controller (in either RAID or IDE mode)
Reply to jlanka
So I should connect my hard drive to IDE 3 which is a ATA133 Raid connector even though I am not going to run raid?
yes. Just disable the RAID and it will act like a regular IDE controller.
Reply to jlanka
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Motherboard problem
There are 1015 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
