Re: Gigab-bites (ouch!)
Have been pulling my hair out with this board, got it because of reviews and actually chose it over the epox from THG review.
Seems to be a definate problem with the AGP4x and 133 bus
My setup:
300W ps
ga-7vrxp mb
AMD 2100 athlon xp
leadtek ge-force 4 ti4400 graphics adaptor
512M samsung pc2700ddr
maxtor 80gig ata133 HD
pioneer dvd rom
LG burner
onboard sound
onboard lan
7vrxp.f8 bios (latest update)
Problem:
With W2k occasionally freezes up at start up - very unpredictable, as soon as begin to run any 3d graphics intensive applications ie UT, SW JK2, DivX movies machine freezes up and need to do a reset.
Have tried fail safe settings, optimized settings, 100Mhz, 133Mhz (took a little longer to freeze at 100Mhz), auto SDRAM freq, 333Mhz SDRAM freq, more RAM, different brand RAM (Kingston)you name it - alas still freezes up when using graphics intensive apps.
I ended up replacing the GEF4 with a GEF2 MX400, haha fixed problem, or so i thought!! didn't freeze up with DivX wow!! then started UT, hey this is great!! going hell for leather when suddenly, the machine resets itself, sh@!xt, back to the drawing board. tried SW JK2 same thing resets after a few minutes on game. Was almost convinced I had an inferior power supply, then came across this and THG forums, looks like I'm not the only one with this problem and seems to be mostly with the GEF4 cards.
Well I am now going to replace the Giga-bite (ouch) with an Epox 8K3a and am going to send a copy of this to GigaByte, I suggest you all do the same thing!!
