Tom's Hardware > Forum > Games General > PC Gaming > Help with frame rates
Forum Games General : PC Gaming - Help with frame rates
Hi. I'm no expert, so I thought I'd ask here.
I got a new PC in November. The spec is:
Core 2 Duo E6600 @ 2.4Ghz
nVidia GeForce 7950GX2
2GB Samsung DDR2 SDRAM @ 667Mhz
19" analog flat panel monitor (my old monitor, didn't come with new PC)
I've noticed a lot of games (Need for Speed Carbon, Top Spin 2, TrackMania United, The Race - WTCC) struggle with the frame rate at max settings. TrackMania, for example, will only give 60fps @ medium quality, in 1280 x1024. Things like turning shadows and motion blur on seem to be a big problem.
I've made sure the games are all using both cores (Task Manager, right-click process, choose Set Affinity) and in my nVidia control panel I've turned on Multi-GPU (someone else told me about "SLI" options, but I can't see such an option in nVidia's contrl panel - I'm guessing "multi-GPU" is the same thing???)
Do you guys think all the above is expected? Or am I doing something wrong? After spending £1,400 on a PC with no monitor I was kinda hoping for good frame rates with high quality visuals.
Thanks folks
Sponsored Links
Quote :
Wow, with that machine, you should be running things higher than that. One thing I can think of is, do you have the Anti-Aliasing turned up all the way to 8x? If so, that would be the thing slowing it down.
also try defragmneting your hard drive, as that can slow things down a bit.
Reply to insan3
I normally have anti-aliasing set to 4x (that's usually the max available - in TrackMania it has on option for 6x, but it says N/A next to it).
Isn't AntiAliasing all part of a better image quality though?
Would I get a better effect with other options on and AA off?
I did a benchmark at Max settings in (AA x 4) Trackmania, and got an average of 26fps. Turning AA off and still with everything else at Max I got 29.7.
Reply to markmcrobie
There are 1069 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
