Tom's Hardware > Forum > Systems > HP > Problem with HP PSC 1210 all-in-one
Forum Systems : HP - Problem with HP PSC 1210 all-in-one
Archived from groups: comp.sys.hp.hardware (More info?)
Hi,
I recently purchased a new HP PSC 1210 all-in-one printer/copier/scanner,
and installed it in a new Windows XP Pro workstation.
When I boot the system, the PSC 1210 driver takes over 1 minute to initialize...
and I can't run any other applications while the PSC 1210 driver is initializing!
This means that I have to wait over 1 minute to use my computer after it
boots, which is extremely annoying! (i.e., this HP PSC 1210 driver obviates
the very fast 4 second boot time of my Windows XP workstation).
BTW, my PSC 1210 all-in-one is connected to a USB 2.0 port using a new USB
2.0-compatible USB cord... and I have tried plugging the cord into different
USB ports... but with th esame unfortunate 1+ minute delay at Windows startup
Has anyone found a way to speed up the HP PSC 1210 driver initialization,
or is this driver really this slow?!
Thanks in advance,
~Matt Verona
Houston, Texas
Sponsored Links
On 19 Apr 2004 06:06:37 -0500, "Matt Verona"
<mattverona@houston.rr.com> wrote:
>Hi,
>Thanks in advance,
>~Matt Verona
>Houston, Texas
Have you tried reinstalling the drivers. I have a 1210 xi and have not
had any problems.
I also didn't install all their software, just the drivers but when I
did install everything I didn't have any problems.
It might be conflicting with something else that is loading on boot.
Good luck
Reply to Anonymous
Are you certain that it is the 1210 that is causing the delay? I ask
because the Symantec utilities have a bug in one version which creates
a 90 second delay after Windows is done loading but before full
functionality (and the Windows opening chord) appears. There is a fix
available.
Dick Ballard
ballardr@att.net
>Hi,
>Thanks in advance,
>~Matt Verona
>Houston, Texas
Reply to Anonymous
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
