Tom's Hardware > Forum > Games General > PC Gaming > 60 frames is the max? problem...
Forum Games General : PC Gaming - 60 frames is the max? problem...
(my pc specs are in my sig below)
been frapping my ownage on fear lately but ive been noticing that the maximum frames ive been getting is 60, and i know something is wrong cuz my other buddies get like 200+ and they have worse rigs than me. Is there some option or something that can remove the 60 frames "limit" ?
ty..
Sponsored Links
7800GTX
2gb OCZ ram
amd 4400+
i doubt its my rig.
i tried the v-sinc but still the same, i read on some other forum that i will still SEE 60 if i turn v-sync off but its actually more, but my freinds say that they actually SEE it say 100+ frames.
im running it on 1024*768 and minimum settings, so im sure my fps should be 100+.
Reply to mo26
k ive just been working with my freind found out its the freekin G5 logtiech laser mouse, i unplugged it and my frames went sky rocketting 200+ instantly, crazy stuff, guess i have to find a way around this now.....thx for the help anyways, peace!
Reply to mo26
why do you want more than 60 FPS anyway, your eye wont even notice it :twisted:
Reply to xblackdemonx
because when you start frapping the frames go down to 30
Reply to mo26
Quote :
oh but you will:D
Reply to av1on
Doom 3,Quake 4 and i think Fear uses a thing called fixedtic(regulates fps to 60)look in the base folder and find the cfg.file open with word and set it to 0
Reply to AgnostiC
Doom 3,Quake 4 and Fear use a command called fixedtic(regulates fps to 60)servers set it to 1 so everyone is at 60 and even. but if server not running the tick(sometimes they turn it off)then you can explore to your base folder in the required games directory and pull up the cfg in word and scroll down till you see it and change it to 0.If your savvy with your cfg file then why dont just make an autoexec.
Reply to AgnostiC
Quote :
7800GTX
2gb OCZ ram
amd 4400+
i doubt its my rig.
turn up the settings you 7800GTX can handle 1280*1024 with max settings(no soft shadows though) i think you probs CPU limited, keeping the settings that low.
Reply to Flakes
There are 1239 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
