Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Where is the fire wire port?
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Good Morning,
When I brought home my Sony Vaio PCG-K13 laptop, I was disappointed to
find that it doesn'thave a fire wire port. Last night, I happened across
a description of the machine on Amazon.com. It says it does have a fire
wire port. Fire Wire is iee 1394 or something like that, isn't it? The
machine's OS indicates it does have a 1394 port.
I'm more familiar with Macintoshes. Do their firewire ports look
different? On the Macintosh, the are about the size and shape of a USB
port, but a little wider, with a kind of triangle shape on each end.
There's an RJ-45 jack. That's what I call an Ethernet jack. Does this do
double duty as a Fire Wire jack? I don't think my macintosh Fire Wire
cables would plug into it. Do I need an adaptor or something? It looks
like the machine has three USB 2.0 ports. Two on the side and one on the
back. Is there an adaptor that will turn a USB port into a Fire Wire port?
There's a tiny little jack right next to the two USB ports. It looks
like the mini-USB jack on a digital camera. Is this an alternate type of
FIre Wire port?
Boy, am I confused.
Thanks in advance,
Tim Miller
Sponsored Links
"Timothy Miller" <noname@nospam.com> wrote in message
news:40DC72E0.9070803@nospam.com...
> Good Morning,
> find that it doesn'thave a fire wire port. Last night, I happened across a
> description of the machine on Amazon.com. It says it does have a fire wire
> There's a tiny little jack right next to the two USB ports. It looks like
> the mini-USB jack on a digital camera. Is this an alternate type of FIre
> Wire port?
> Boy, am I confused.
> Thanks in advance,
> Tim Miller
If the port were up your âss, you'd know where it is!
Reply to James
It has a FireWire port, only labeled iLink S400 (4pin)
It's under the left side airvent, between mic and USB ports
Tumppi
Reply to group
Most learned here on nntp://news.mircosoft.com
Helsinki, Finland (remove _NOSPAM)
(translations from FI/SE not always accurate)
"Timothy Miller" <noname@nospam.com> kirjoitti viestissä
> Good Morning,
> FIre Wire port?
> Boy, am I confused.
> Thanks in advance,
> Tim Miller
Reply to Anonymous
There are two different types of fireware ports. The one you described (with
the triangular ends) is for devices with no external power. What your laptop
probably has is the mini jack that is for devices that have their own power.
It should be the one you mentioned, near the USB ports.
HTH, JAX
> Good Morning,
> FIre Wire port?
> Boy, am I confused.
> Thanks in advance,
> Tim Miller
Reply to Jax
James wrote:
> "Timothy Miller" <noname@nospam.com> wrote:
>>Good Morning,
--snip--
Hey, Beavis! I'm one of your biggest fans. Can I get your autograph,
dude? Just write it on your screen with a magic marker.
Thanks to Thomas an JAX on this thread. It's obvious now, but it wasn't
obvious at the time, at least to me.
Cheers,
Tim Miller
Reply to Anonymous
You're welcome Timothy.
JAX
news:40DE57F3.8090904@nospam.com...
> >>Good Morning,
> --snip--
port?
> Cheers,
> Tim Miller
Reply to Jax
There are 1193 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
