5.1 sound system!
Hey guys
I just wanted to know how i would connect my 5.1 speakers to my iMac since it only has an audio jack, and my speakers have 3 leads.
I normally plug these 3 into the back of my 7.1 motherboard on my PC, but since the imac only has 1 audio jack i was wondering if i need some sort of external converter, e.g the THX external sound card.
Problem is that i dont really want to be spending more than £30 on this, will this affect sound quality? and what are good models to go for?
THanks!
3 answers Last reply
More about sound system
  1. I believe some of the audio jacks on Macs have optical out in the same port as the 1/8 in stereo plug. I've never tried it myself. The optical out lets you get 5.1 out but using a stereo jack only gets you stereo out.
  2. The optical out only supports surround sound for audio tracks that have embedded digital surround. It works great.
  3. I use a mini TOSLINK adapter ($2.99) and it works great. You will need an app such as Soundgarden to control the volume/dither if you use optical. For a little more money you can buy a TOSLINK cable with a mini end for use with Mac's.
Speakers iMac Mac OS X
