power scan ?
Forum Windows XP : Windows XP General Discussion - power scan ?
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
2 things really.
I've been removing virii for several days now. It would seem XP is especially
vulnerable. or harder to clean than a win98 machine. The same thing pops up
over and over.
Something happened today the search from toolbar died. whatever I put up there
ie:sam spade, now appends http:///sam%20spade to the address bar. jumps you to
a dead link. Obviously. it's a syntax thing.
I just fixed this exact same problem on win98 a week or two back, but my notes
no longer exist on this machine on what I did. I thought I most likely used
repair Internet explorer, but that option doesn't seem to exist, or I can't
find it anymore and the troubleshooter doesn't mention it either.
does the repair option still exist and if so where ?
more pix @ http://members.toast.net/cbminfo/index.html
Sponsored Links
Hello
How to run System File Checker
Start>Programs>Accessories>Command Prompt>(type) sfc /scannow (notice the
space between sfc & /)
How to do a repair install, scroll down to How to Repair Install.
http://www.webtree.ca/windowsxp/repair_xp.htm
Hope this helps
Haus
Good Luck
"Husky" <cbminfo@toast.net> wrote in message
news:vkvne0p68h1ufav9bc9em5phjmr6mhomje@4ax.com...
> 2 things really.
especially
up
> over and over.
there
you to
notes
used
can't
Reply to Anonymous
On Wed, 7 Jul 2004 10:00:19 -0500, "Haus" <youknow@Iwillslapyou> wrote:
System file checker isn't exactly Internet explorer specific.
What I used to have was ie6 setup.exe on the win98 machine, and whenever things
got nasty, it was simpler to try a repair, then go for a reinstall if things
were that bad. repair usually did the trick.
That's what I'd prefer vs this system file checker.
>Hello
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > power scan ?
There are 1114 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
