Ok Ive installed Oblivion and I load it up and works fine until its finished telling me the story, it closes down and tells me theres an error occured and has to be closed, sorry for the inconveinience..
This Is the System im using:
Name: NVIDIA GeForce FX 5700LE
Manufacturer: NVIDIA
Chip Type: GeForce FX 5700LE
DAC Type: Intergrated RAMDAC
Approx. Total Memory: 265.0 MB
Current Display Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Try lowering the graphics to there absolute minimum,
Your computer specs bearly reach the requirements. I know it sound mean but that is the most likely reason it would crash like that. Once the movie has ended the framerate would drop real low beause it free rand viewing.
