Wifi dropouts/ intermittent connection
Last response: in Wireless Networking
Archived from groups: alt.internet.wireless (More info?)
Hi
Have installed a week ago a netgear wifi/adsl router (DG834G). All
went in OK. I've patched the router/AP to the latest version of the
firmware (1.05). Connection is via 2laptops - a HP P4 with an inbuilt
Broadcom 802.11b card and a Toshiba P4 with a netgear 802.11g pcmcia
card both running XP. Access point is in study upstairs, living room
is downstairs, I've set the antenna parallel to floor. I get either 4
of 5 bars or 5 of 5 bars signal (on the strength on the 802.11b
(11mb) card, even right before it drops out.
Dropout is intermittent and I can't find anything happening at the
same time. I've no major RF devices real close, although there is a tv
a couple of metres away it wasn't even on this morning when it did it
- fairly typical example - turned laptop on, went onto 'net, been on
for about 3 mins and the next page wouldn't load. Try to ping router,
no response. The little network icon thingy in the bottom right hand
corner still thought I had a connection though (might not have timed
out to it's next check perhaps ? Couldn't find a refresh interval
setting). Turn off card (the HP has a little button on the side of the
laptop) wait 30secs, turn on...it then works fine and has done for the
last half hour.
Any suggestions ?
Oh yeah, I'm using WPA-PSK, TKIP if that matters, and there is another
wifi somewhere close by that I can see with my card.
JL
"John Littler" <jlittler@my-deja.com> wrote in message
news:50d6805e.0407311559.6d82ae6f@posting.google.com...
> Hi
> last half hour.
> Any suggestions ?
A possible solution is to disable the Wireless Zero Configuration Services
that can drop your connection as it seeks out other networks in your area.
The connection on my XP pro laptop would drop the connection continuously.
Also, I don't us the card's utility to show signal strength or anything. It
is not installed . I installed the driver and configured it with Device
Manager.
The signal strength will be shown by XP, if the XP NIC icon is in the System
Trey and it is moused over.
Duane :)
Got the same prob :
linksys WAG54G
acer aspire notebook with an nw card intel 2200BG
winxp pro
My prob started out with sometimes losing connection, and could not
get the connection backup until i rebooted.
So i started out doing stuff, that made it worse: windows updates, MS
knowlegdebase stuff. Also updated the firmware of the linksys, tried
altering the settings in linksys (from real secure to totally unsecure)
but nothing helps. I keep getting these disconnects / reconnects every
30 secs or so. Its driving me mad.
So if anyone finds a solution, please keep me (the forum) posted.
thx,
LuX
luxifur
brought to you by http://www.wifi-forum.com/
If you're using the wireless config that comes with XP, disable it and
try the software that comes with your wireless card. I've found the XP
stuff constantly searches for another connection, when it thinks it
found one, it drops your good connection. Drove me crazy 'til I figured
it out and quit using it.
luxifur wrote:
> Got the same prob :
> linksys WAG54G
> winxp pro
> thx,
> LuX
Related ressources
Make sure the SSID is in a broadcast mode.
"luxifur" <luxifur.1abwjm@no-mx.forums.yourdomain.com.au> wrote in message
news:luxifur.1abwjm@no-mx.forums.yourdomain.com.au...
> Got the same prob :
> linksys WAG54G
> winxp pro
> thx,
> LuX
> luxifur
XP Pro is very fussy working with other vendors' configuration programs,
and there are many gotchas in setting it up. I'm using a D-link 2100AP
access point connected to a router on a 98SE machine, and a G-650 card
in an XP Pro Dell laptop. I spent about 2 days trying to get the D-link
configuration program to work for all users on the laptop. End result -
it doesn't - it makes things worse. You don't need it. Here's how I
finally got it to work.
On you machine connected to the wireless access point:
Set it up for SSID broadcast, encryption on, open key, WEP, Hex key, 64
bit. Enter a 10 digit key using only 1-9 and A-F. Name your SSID
something other than 'default'.
1. On your XP slave: Log on as administrator. Be sure your wireless
card is plugged in. Uninstall any third party wireless configuration
software.
2. Right click on 'my computer', then left click on 'manage'. Double
click on 'services and apps', then 'services', then 'wireless zero
config' in the list on the right. Select in the 'general' tab -
'startup type - automatic'. If applicable, click on 'apply', then
'service status' and 'start'. You want to end up with 'automatic' and
'started'.
3. Click the 'logon' tab. Select the 'local system account' radio
button and check 'allow service to interact...' Click 'OK'. Reboot.
Relogon as administrator. Right click on the network icon in the system
tray. Select 'View Available Wireless Networks'. You should see your
renamed SSID. Select it and click 'advanced'. Delete everything in
'preferred networks'. 'Use windows to configure...' should be checked.
Select your SSID again and click 'configure'. For 'network
authentication' select 'open'. For 'data encryption' select 'WEP'.
Enter the same 10 digit hex key used to set up the AP.
4. Click on the 'authentication' tab. Check 'Enable IEEE...'. EAP
type should be 'smart card'. Click 'properties'. Select 'use my smart
card'. No other checks. click 'OK'.
5. Uncheck 'Authenticate as computer...'. Check 'authenticate as
guest...'. Click OK. You should be back at the 'Properties' window.
Click 'Advanced' Select 'Access point...'. Click 'Close'. You should
be at the first window with your SSID in the 'preferred networks' box.
Click 'OK'. Reboot.
Notes:
With this setup, every time you change users you have to click 'remove
hardware' in the system tray, unplug the card, and re-insert it when you
are logged on as the new user. There might be a way around this, but I
haven't found it.
This setup works. There are no conflicts and the connection is steady
and stable. If anybody knows a simpler method, or if any of these steps
are unnecessary, please let us know. Good luck!
Lance Courtland
>>Got the same prob :
>>linksys WAG54G
>>winxp pro
>>thx,
>>LuX
>>luxifur
software.
'started'.
Click 'OK'. Reboot.
Notes:
haven't found it.
Lance Courtland
>>Got the same prob :
>>linksys WAG54G
>>winxp pro
>>thx,
>>LuX
>>luxifur
software.
'started'.
Click 'OK'. Reboot.
Notes:
haven't found it.
Lance Courtland
>>Got the same prob :
>>linksys WAG54G
>>winxp pro
>>thx,
>>LuX
>>luxifur
The bottom line with my XP PRO set of machines on wireless; I don't use
the card's utility to set up the card. It's not even installed on the
machine.
I downloaded the driver for the card and installed the driver and
configured the card with Device Manager.
I disabled the Wireless Zero Configuration Service on the XP O/S, which
makes it seek out other networks dropping the connection.
I enable in the NIC's properties screen to *show network connection
icon*, which allows the mouse over on the icon in the job trey to show
signal strength.
I have a couple accounts I use to login to the wireless laptop with no
problems.
Prior to that, the wireless setup was a PITA.
Now it's solid as a rock like it was when the laptop was Win 2k
Duane :)
Thanks for the posting Lance, after a fair bit of googling and for the
record the most stable configuration turned out to be (and I'm
guessing this will come as *no* surprise to a few people)
-Turn off the wireless zero config service
-Use the config utility that comes with the card
- Reorientate AP to maximise signal
Noting that on one laptop I turned zero confgi off, the other (the
netgear one) it doesn't seem to make any difference albeit it was
dropping out less anyway
This brings it down to an occasional dropout, I can live with that
From my research so far I'm a little concerned with a couple of
comments below (if you don't mind me saying)
WEP is the equivalent of those padlocks they put on the $2 diaries for
little kids, use WPA/(other?) if you're concerned in the slightest
about security
Why would you swap from authenticate as computer to authenticate as
guest ?
I'm still a newbie on the wifi so let me know if there's something I
misunderstood
JL
Lance Courtland <oscarman4@yahoo.com> wrote in message news:<xZiPc.199561$IQ4.159770@attbi_s02>...
> software.
> 'started'.
> Click 'OK'. Reboot.
> Notes:
> haven't found it.
> Lance Courtland
> >>Got the same prob :
> >>linksys WAG54G
> >>winxp pro
> >>thx,
> >>LuX
> >>luxifur
For antenna orientation, I place the laptop where I want it to be, and
start the signal strength measurement tool (maybe the client software,
maybe NetStumbler). Then I start a VNCserver on the laptop.
On another computer near the WAP (a desktop in my case), I start a
VNCserver to watch the laptop screen.
Antenna adjustments are made according to the signal strength as seen at
the laptop, and VNC itself generates enough traffic to make Orinoco Client
software provide a nice chart of packets.
http://www.RealVNC.com
http://www.NetStumbler.com
Actually, I determined exactly the opposite. Setting it up like that
caused the dropout problems.
<snip>
> guest ?
I don't know why, I just determined that that's the setting that worked.
All of these settings were discovered by trial and (lots of) error.
That's why I can't say what's necessary or not.
Lance Courtland
dold@WifiXdropo.usenet.us.com wrote in message news:<celqgc$rbu$1@blue.rahul.net>...
Noice ! Ta.
JL
Ask the community
