Archived from groups: microsoft.public.windowsxp.newusers (More info?)
HELP! I loaded the XP Home upgrade on 10 July (I
previously had Windows 98)- and now my Norton Internet
Security and Antivirus software don't work. I've
uninstalled and reinstalled NIS - and it still doesn't
work.
Question 1 - how can I make it work?
Question 2 - does XP have somne sort of protection
embedded so I can fend off attacks if I log onto the
Internet while I try & fix the Norton problem?
Re Outlook & Outlook Express - I have no messages,
everything's gone. Why? XP warned me that I'd have to
reload Outlook from the Office 2000 Small Business disk,
so I did, but should that also have wiped Express? I did
do a backup before loading XP - can I use it to restore my
e-mails? For some reason, my contacts list does still
exist.
And another thing - why on earth is Microsoft telephone
support so dire? Only open 8am-6pm, Monday to Friday? I
spent 45 minutees on hold to a call centre in India, and
didn't get even a sniff of a technician. Obviously, I have
not been called back as promised...
Mary Sauer MS MVP
http://office.microsoft.com/ http://www.mvps.org/msauer/ news://msnews.microsoft.com
"Yvette Rathbone" <yvette.rathbone@mitsubishi-sec-intl.com> wrote in message
news:2b9b601c467f9$3cd116f0$a301280a@phx.gbl...
> work.
> exist.
> Thanks to anyone who can help me.
Thanks Mary - I have Norton Internet Security 2003, which
is supposed to be XP compatible, at least with the 32-bit
version. I imagine that's what I have, since I have the XP
home upgrade.
>-----Original Message-----
>What version Norton?
>Symantec Norton Anti-Virus 2001 Is Not Compatible with
Windows XP
>http://support.microsoft.com/default.aspx?scid=kb;en-
us;286601&Product=winxp
>Visit the Symantec web site, they maybe more helpful
>http://www.symantec.com/techsupp/
>Microsoft has a firewall you can enable
>Open Network connections, right-click Local Area...
properties, Advanced tab, check
>the Internet Connection Firewall
>OLEXP: How to Import and Export Address Books in Outlook
Express
us;175017&Product=oex
>OLEXP: How to Manually Export and Import Messages in
Outlook Express
us;257173&Product=oex
>Mary Sauer MS MVP
>> work.
my
>> exist.
have
You have the 32 bit version, as Home Edition does not come in 64bit, and you would have spent a few thousand more had you had that system.
Anyway, did you upgrade over 98? Did you also see if your system is compatible with XP, since many hardware and software devices will run under 98 easily, but may be too old for XP.
"Yvette Rathbone" <yvette.rathbone@mitsubishi-sec-intl.com> wrote in message news:2ae4301c46809$a4093e00$a501280a@phx.gbl...
> home upgrade.
> Windows XP
> Express
> Outlook Express
>>Mary Sauer MS MVP
>>> work.
> my
>>> exist.
> have
Hi Tom, yes I did upgrade over W98 - second edition, I
think, though I'm not 100% sure of that. I checked
everything I could check before the upgrade - RAM,
processor speed etc - and that was all fine; then I read
all the Upgrade Adviser stuff which was generated after I
inserted the XP disk - and no mention was made at all
about Norton. It did tell me about some incompatibility
issues e.g. that I would need to reinstall Microsoft
Outlook, and upgrade my DVD decoder. Forgot to mention in
my earlier post - after I reinstalled NIS I still couldn't
open it & got the same message about needing to uninstall,
along with a Visual C++ Runtime error to do with IntroWiz.
When I tried to re-uninstall, I got a message that only an
account with supervisor access can uninstall it. I'm the
only user of the PC, so I don't get that at all.
old for XP.
which
bit
XP
>> home upgrade.
>> Windows XP
Outlook
>> Express
>> Outlook Express
>>>Mary Sauer MS MVP
>>>> work.
disk,
did
restore
>> my
>>>> exist.
telephone
I
and
>> have
Then you will need to log into safe mode, and use the Administrator (supervisor as you say) account to do what you need. Only you know how to do this with your PC. Sometimes when you restart, hitting the delete key a few times will give you this option, or hitting the F8 key will do this. When you get the list of what to choose to log into, choose safe mode.OK. I am guessing you didn't set a password for administrator.
Then try uninstalling all of what you need. You also may want to check the Symantec wbsite for unistallers they provide also before doing this. I have read issues with others not being able to do what you need. Personally, I wouldn't Symantec (nortons products) except for maybe their backup programs. You can get good firewalls free, and AV programs free or cheaper that are less intrusive than Symantecs products, and do a better job.
"Yvette Rathbone" <yvette.rathbone@mitsubishi-sec-intl.com> wrote in message news:2a81401c46810$0fbf57a0$a601280a@phx.gbl...
> old for XP.
> which
> bit
> XP
>>> home upgrade.
>>> Windows XP
> Outlook
>>> Express
>>> Outlook Express
>>>>Mary Sauer MS MVP
>>>>> work.
> disk,
> did
> restore
>>> my
>>>>> exist.
> telephone
> I
> and
>>> have
Thanks Tom. Assuming I can actually get rid of Norton,
what firewall/AV programs would you recommend? I 've read
some comments (on AVG, I think - one of the freebies,
anyway) saying that they can be very slow to provide virus
recognition tools.
read
I
in
couldn't
uninstall,
IntroWiz.
an
the
your
too
>> old for XP.
>> which
>> bit
the
>> XP
>>>> home upgrade.
with
>>>> Windows XP
>> Outlook
>>>> Express
>>>> Outlook Express
>>>>>Mary Sauer MS MVP
Internet
doesn't
>>>>>> work.
to
>> disk,
I
>> did
>> restore
>>>> my
still
>>>>>> exist.
>> telephone
Friday?
>> I
India,
>> and
I
>>>> have
Well, you sound like you take care of how you operate your PC and are careful, that is a big plus right there. Many here swear by AVG, Panda, etc, and there are others. Sygate, Zone Alarm,, Kerio, and Tiny all make good free firewalls, except the newest version of ZA has problems at the moment, but I like that version best. if you get it, get the 4.5.594.000 from here (not the 5.0 flavors, they have minor bugs still):
I personally do not use an AV, but that is me, and I would never recommend that to one who may be unsure of themselves, as I am fairly good with PCs. But I do use Trend Micros online scanner, which is free and totally non-invasive, and is an effective virus/trojan remover. Panda has been getting ggod reviews with their free online scanners. If you want one installed AVG is good, Panda, Kapersky also, and cost less then Nortons and is not as intrusive. Nortons tends to want to take of what Windows can do on its own, and removes things ity deems non essential, until it is too late.
If for some reason you are screwed, you may want to totally reinstall windows, which would be a hassle, and hopefully, you have backed up your essentials, or you still can.
"Yvette Rathbone" <anonymous@discussions.microsoft.com> wrote in message news:2bbb101c46818$466d2b80$a301280a@phx.gbl...
> recognition tools.
> read
> I
> in
> couldn't
> uninstall,
> IntroWiz.
> an
> the
> your
> too
>>> old for XP.
>>> which
>>> bit
> the
>>> XP
>>>>> home upgrade.
> with
>>>>> Windows XP
>>> Outlook
>>>>> Express
>>>>> Outlook Express
>>>>>>Mary Sauer MS MVP
> Internet
> doesn't
>>>>>>> work.
> to
>>> disk,
> I
>>> did
>>> restore
>>>>> my
> still
>>>>>>> exist.
>>> telephone
> Friday?
>>> I
> India,
>>> and
> I
>>>>> have
> work.
> exist.
For your OE problem :-
98 stored the DBX files and Address Book in a Windows\Application Data
folder.
XP stores them in the Documents and Settings\<username>\local
settings\.....
folder.
Open Windows Explorer
Tools | Folder Options
Select "Show all files"
uncheck only Hide file extensions fro known file types.
click apply then ok
Now, navigate to the Windows\Application Data folder.
Drill down till you file the Inbox.dbx file.
Do the Same for the Address Book's wab file.
Write down these locations.
From OE:
File | Import | Messages | Microsoft Outlook Express 6 | Import mail
from an
OE6 store directory.
Press OK
Press Browse and navigate to the folder where the dbx files were found.
Select it then press OK and finish up the import.
For the Address Book, File | Import | Address Book
navigate to the folder where the WAB file was found and import it.
