Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I installed a veo advanced web cam and went to web site to install drivers and software. I installed it and am unable to take snapshots. I receive this:
access violation @ address 01A63B0C in module camcapex.dll Read of Address 00000008
I am able to record my voice and record a video email, but not snap a photo. Why is it doing this? Microsoft says that I may be missing a standard PCI or need to update a USB Driver. There are none to be updated.
I emailed tech support at VEO and they said that this error message is because:
The camera system files you are using are mismatched, preventing the Veo Digital Studio from working properly. Microsoft Windows Update has attempted to update the Veo Advanced Connect when you last connected to the Internet.
They suggest that I disconnect web cam and ethernet but if do this I cannot download and re-install the veo driver and software from website! I will not have internet access.
I do not have a CD-ROM to install webcam with as it was cracked. Can you please help me so i may send my photos to mi familia in Bogota.
Have you tried disconnecting the camera and running the driver update from windows update? You may need need to disable your ethernet card.
Regards
Dan
> Thank you, Issa
Yes, tried that too. But the problem is that the update from windows is mismatching the drivers and causing this error. Thanks for your response. Any other suggestions?
> Regards
> Dan
> > Thank you, Issa
Tried it, but the problem is that the update from windows is wrong and mismatches the drivers thus causing this error code. Thanks for responding, Dan. I appreciate any help you offer. Got any other suggestions? Thanks again!
Issa
> Regards
> Dan
> > Thank you, Issa
Have tried that, Dan but the problem isthat the update from windows is mismatching the drivers thus causing the error message. *sigh*
Thanks for responding, Dan. Have any other suggestions? let me know. And thanks again.
Issa
> Regards
> Dan
> > Thank you, Issa
> Regards
> Dan
> > Thank you, Issa
> Regards
> Dan
> > Thank you, Issa
Wow you tired that a lot of times!! ;-)
Is it possible to uninstall your camera and reinstall it with the latest driver download from the Veo website. And then avoid downloading the update from windows update again.
> > Regards
> > Dan
> > > Thank you, Issa
