First here is my setup:
ASUS A7V
T-Bird 1400
512 RAM
300W PS
I keep the thing running 24/7 and I came home from work and noticed the monitor was blinking like it does when the comp is off, the lights on the case were flashing also. I turned the power off, waited a few and pushed the button to turn it back on and got zip.
I opened it up a noticed my HS was hanging by only one clip, the other tab on the mobo was broken off (think kids knocked it over and won't fess up). Also noticed there was some light burn marks on top of the chip. Uplugged power cord, removed the chip checking for any cracks or chips but didn't find any and put it back in. I layed the comp on its side and just set the HS on top of the chip, plugged power cord back in and immediately got the green light on the mobo, pushed the power button and the fan on the HS spun for a split second, the lights on the front of the comp came on and went out.
Can get the same results each time I unplug the power cord and let it set for a few seconds. I pulled the T-Bird 1400 and replaced it with a T-Bird 850 I know is good but got the same results. Any ideas?
ASUS A7V
T-Bird 1400
512 RAM
300W PS
