Tom's Hardware > Forum > Systems > HP > Audio problem on Omnibook 4150 (Neomagic)
Forum Systems : HP - Audio problem on Omnibook 4150 (Neomagic)
Archived from groups: comp.sys.hp.hardware (More info?)
I was wondering if anyone can help me with a problem I have had for some
time with my Omnibook 4150. During playback of mp3 files using either
WinAmp or other mp3 players and also during playback of DVDs using
PowerDVD the audio driver appears to crash and the sound of the mp3 file
or dvd is replaced by a sort of loud distorted buzzing sound. The audio
card drivers are NeoMagic MagicMedia AV256.
Sponsored Links
> some time with my Omnibook 4150. During playback of mp3 files using
> either WinAmp or other mp3 players and also during playback of DVDs
> using PowerDVD the audio driver appears to crash and the sound of the
> mp3 file or dvd is replaced by a sort of loud distorted buzzing
> sound. The audio card drivers are NeoMagic MagicMedia AV256.
First reinstall the audio driver and see if that helps. If it is only
ocurring with mp3 and DVD, you might have a corrupted audio or A/V codec
or do not have the proper ones installed. If you are running DirectX,
you might try the audio portion of dxdiag.exe and see if it turns up any
audio errors that could point to the source of the problem. In the
audio controls, verify the mapping to devices is correct and that you
haven't installed an alternative software audio driver that is set as
the default device for playback.
Q
Reply to Anonymous
There are 1226 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
