Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Connecting Cantenna to Wireless PC Card
Forum Wireless Networking : Wireless General Discussions - Connecting Cantenna to Wireless PC Card
Archived from groups: alt.internet.wireless (More info?)
I have an Octopus IEEE 802.11b WLAN Card (see a picture here
http://www.success-hk.com/sc_html/ [...] ard.htm#).
I have been reading about making your own cantenna and one of the
steps is to connect a pigtail to the wireless card. However, by
looking at the picture of a pigtail and its connecters, I can't figure
out how I would connect the small end to my wireless card, since it
has no holes. Am I just unable to use a cantenna with my particular
wireless card?
By the way, I'm using the instructions at
http://www.turnpoint.net/wireless/cantennahowto.html regarding how to
make a cantenna.
Thank you for any help you can provide!
Sponsored Links
> wireless card?
> make a cantenna.
I couldn't find any detailed specs on the Octopus card, but it appears
that it does not have an external connector. If this is the case, you
have a tough row to hoe to connect a cantenna. It would probably be
easier to buy another card that has an external connector. Or you could
try making a reflector for your card, might boost the signal some.
This link, almost to the bottom, describes your problem:
http://www.seattlewireless.net/index.cgi/PigTail
Reply to Roger
Rôgêr <abuse@your.isp.com> wrote in message news:<410EBE1F.4000005@your.isp.com>...
> > wireless card?
> > make a cantenna.
Thanks for the help! After checking out the seattlewireless.net link,
I don't think I am going to be able to do the hack they describe. It
looks like removing the plastic on mine might be too destructive, so
it appears my only option is get another one with a connector outlet.
Thanks, again!
Reply to Anonymous
> Thanks, again!
If you are looking for a new purchase, my testing over the weekend shows a
DLink DWL-122 mini-usb in a can to be better than an Orinoco in the same
can for signal strength. The mini-USB seems more directional, and
sensitive to positioning, but at its peak, it is better and cheaper than an
Orinoco with a pigtail.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
Reply to Anonymous
There are 842 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
