Tom's Hardware > Forum > Systems > HP > HP PSC 2510 and TrayApp installer problem
Forum Systems : HP - HP PSC 2510 and TrayApp installer problem
Archived from groups: comp.sys.hp.hardware (More info?)
Installed this and whenever I try to run either HP Director or the HP
Digital Imaging Monitor it tries to install something called TrayApp.
It then asks me to point to the trayapp.msi on the Cd but then tells
me this is not a valid installation file.
I can't seem to get anything working yet with this software
Any ideas?
Thanks
Gordon
Sponsored Links
I am having same thing.....please help.
Reply to Anonymous
Identical problem heere....please hlep
Reply to Anonymous
I get an error (1706) saying : no valid source can be found for product
TrayApp- the windows installer can not continue"
Anybody knows what is this about ?
thanks hosseind
Reply to Anonymous
HP
TrayApp.
tells
> Any ideas?
> Thanks
> Gordon
please plaese please!!!
I'v got the same problem too and have no idea what to doo!
Enyone, help!
Thanks Carla
Reply to Anonymous
I finally fixed it. I had the same error for a long time. Frustrating,
isn't it!
I was online with HP support for hours.
It boils down to this. At some point, somewhere, somehow, all of you
either deleted or uninstalled some printing or imaging software components
from HP.
If you have any CD's of recently installed printer software, like I did,
insert the DVD/CD when prompted to install the TrayApp. Then, navigate to
the folder on the disk called, "TrayApp", in there you will find a .msi
installer called, "TrayApp".
Click on that, hit OK and the Imaging Monitor should extract the trayapp
automatically.
Tray App installers are on the Image Zone Disks that came with your
computer and almost alway on printer software installers.
Good luck.
Dave
Reply to Anonymous
This is not the solution. I have done this a half dozen times and the
problem keeps coming back.
I think the problem is somehow related to a problem with .NET. My .NET
Connection Service cannot start because it cannot find the executable
in the path. It just a hunch that, becaue HP seems to use .NET very
heavily, and, because, .NET can seem to be working while it is having
esoteric problems, that this problem lies there.
Greg Silverman
Menlo Park, CA
Frustrating,
> isn't it!
components
> from HP.
did,
navigate to
..msi
trayapp
> automatically.
> Good luck.
> Dave
Reply to Anonymous
Ugh! Did Bill Gates or Steve Ballmer kiss Carly to get HP to use .NET ???
This is a needless complcation and explains why HP printer software installs
often get screwed up !!!! ... Ben Myers
>Greg Silverman
>Menlo Park, CA
>Frustrating,
>> isn't it!
>components
>> from HP.
>did,
>navigate to
>.msi
>trayapp
>> automatically.
>> Good luck.
>> Dave
Reply to Anonymous
- 0 +
I had the same problem with trayapp install at windows start.
We actually fix temporarly the problem with inserting the HP CD at the
dialog box asking for stuff like "trayapp.msi" and "fax.msi".
The problem is coming back after using registry mechanic. I think it
is due to incompatibility between those both softwares. If you do not
want the problem to come again, watch the items selected by registry
mechanic and avoid deleting key referring to HP stuffs
Reply to cedric
I have an HP Officejet 7410 all in one. I get the same error after running
Registry First Aid 4.0 Loading TrayApp.msi from the setup disk does
re-enable HP DIM and it places the icon back in the system tray-- until
you run RFA 4.0 again. The registry entries that refer to TrayApp and
other essential HP Director software need to be excluded from the RFA 4.0
search, even though RFA 4.0 views these files as "safe to correct with
default suggested correction."
Reply to Anonymous
The fix involving finding the trayapp file on an HP install disk
worked for me.
Reply to Anonymous
I've got the same problem with my "All-In-One" HP Photosmart 2710. The
solution (restart with inserted HP-CD) worked fine. :D
Reply to Anonymous
Hi gang,
I have had that same nerve wracking problem! I got rid of it only to
have it rear its ugly head again after installing Windows XP Service
Pack 2 that was sent to me free of charge. (I did so many things that
I can't recall which 'solution' cured it that time.)
Believe me when I say I had a few "air-turning-blue" words dircted to
King Bill. I figured he was going to shorten my life one way or
another through my computer. :?
Then today I saw that someone, (too lazy to check backwards in this
forum to find out who), mentioned 'HP Image Zone'. WHOA!! I
immediately insertd my M305 camera disk, removed the works and
reinstalled it.
So far, great! ... But I'm going to think twice before I have the guts
to install another program. This has really put the fear into me!!
:oops: :oops: :oops:
Charlie
Reply to Anonymous
- 0 +
This is a crazy-making business, all right. My PC finally crashed
and I did a full system recovery, forgot my AOL password for two
days, kept trying to sign on with guesses all that time.
My husband knew I'd finally hit on it, I suppose, and wouldn't call
them, as the account holder. I'll have to think of something to pay
him back.
They ask "security questions" such as your pet's name. I gave all
the pets we've ever had, since our affiliation with them, and they
said none was correct. That can't be right. They didn't even look.
My Word Perfect disk must be getting worn out and a few files would
not install or a path could not be created. I think I might get
Publisher. And maybe even a $200 XP disk. Anyone know how to
clean out the built-in version? Or do you even have to?
Reply to eagle1
- 0 +
him back.
:shock:
Reply to eagle1
Eagle 1,
What version of WordPerfect do you have???
I might be able to help or direct you to the greatest WP group in the
world!
Don't get Publisher until we see about your WP.
Charlie
"My Word Perfect disk must be getting worn out and a few files would
Publisher."
Reply to Anonymous
- 0 +
Hi, CG,
I'm still using Version 9 because I really don't like all the extra's,
Office 2000 or whatever, really just want Word Processing and nothing
else. Now it says WP9 "file cannot be found" but my Norton scan
showed my computer is full of it, also a search turns up 9
components.
Since my full System Recovery, I haven't yet re-installed Service Pack
1 or 2 and all the other updates, or tried to re-install my HP
All-in-One, 1310 Series, 1315. I believe someone in this forum said
SP2 caused some problem. I'll have to read again. Wondering if I
should install the printer/scanner first and then the Windows
Updates.
Another little thing, my Add/Remove is in Control Panel but creating
a desktop icon is grayed out.
Thanks much for your interest and reply.
Reply to eagle1
This CD fix also worked for me. It definently was caused by
RegMechanic!
Reply to Anonymous
HKEY_LOCAL_MACHINE\SOFTWARE\HEWLET-PACKARD\DIGITALIMAGING\HP
PHOTOSMART ****
SERIES\DEVICEINSTANCES\4283CE5D00\STRINGS\\:INSTDATADIR
Thsi is the registry key that casued my problem. when RegMechanic
deleted it the problem started. After putting in the reg mechanic
ignore list the problem went away.
Reply to Anonymous
- 0 +
Okay, we avoid Reg Mechanic.
Also, I bought Registry Repair Pro, and never did read the list
of files it was going to delete, which I'm sure caused my
recent crash. There are always backup files, which of course
disappear the next time you do a scan. Since I'd paid for that
software, I guess I trusted it.
I have Ultra Win Cleaner, pretty good, but I never see it in stores
any more, PC Doctor on Call 2 was good but it's gone too.
Can't think of the names of some other ones I have had since before
buying.
Just now, an update for my HP All-in-One printer they had
installed can't be found, Windows says, may have been moved, or my be
in a network. But I've disabled networking. Also my invitation
to register my re-install of it turned off before I could do
that. Guess I'll go to their web site.
At least now I have the HP Director and Image Zone. Haven't tried
any scanning.
Reply to eagle1
HP
TrayApp.
tells
> Any ideas?
> Thanks
> Gordon
I HAD THE SAME PROBLEM AND I FOUND A DISK CALLED HP IMAGE ZONE WHICH I
HAD INSTALLED PREVIOUSLY FOR AN HP MOBILE MEDIA COMPANION, AFTER THAT
I INSTALLED AN HP PRINTER, WHICH CAUSED PROBLEMS AND I DESINSTALLED
IT. THAT IS WHEN ALL MY PROBLEMS BEGAN WITH TRAYAPP. BUT FINALLLY I
FOUNDTHIS DISK (HP IMAGE ZONE) WHIH WAS PROVIDED WITH THE HP MOBILE
MEDIA COMPANION) AND PUT IT IN, REINICIATED MY COMPUTER AND IT PULLED
THE TRYAPP FILES, NOW IT WORKS FINE.
ALICE
Reply to Anonymous
I have had problems with my broadband connection since this trayapp
window appeared. I usually just close/cancel it but it takes about
ten attempts to get rid of it. I was losing my broadband connection
periodically and could only get it back by dialing any number on the
phone, when I could hear it dialing just like it used to when I had a
dial-up connection. It then disconnected from the broadband about a
week ago and would only stay connected it the phone was engaged.
Today I didn't try to close Trayapp because it was annoying my so I
just moved the window to the bottom of my desktop. The Internet has
been connected every since. HELP!
Reply to Anonymous
- 0 +
I really love my little HP All in One, but how can I find out if it
has a Twain driver, I know nothing about, trying to scan
printed-out music back into a notation program that I lost in recent
computer crash. Anyone know anything about that? Have SharpEye or any
scan program?
For whatever this info is worth, System Restore, the rollback to an
earlier date, will only work a certain number of times. I wasn't
getting anywhere by using the HP disk, so was trying rollbacks,
finally had to do a full F-10 key recovery. I don't know if that
will help anyone.
Reply to eagle1
- 0 +
scan program? Music is considered pictures, only Tif files
compatible with the notation program.
will help anyone.
Wish MS would come out with a new XP home disk. People are still
using the 2003 one. Or would that cause us new problems?
Reply to eagle1
One way to find out if your All in One has a Twain driver is to download
IrfanView (written by Irfan, of course), a very useful and very much free image
manipulation program. Using it, I can scan directly from my Twain complaint
old-time SCSI scanner. Not sure if it will scan to a TIF image, though... Ben
Myers
On Wed, 31 Aug 2005 00:31:03 GMT, lesliebuc@aol-dot-com.no-spam.invalid (Eagle1)
>will help anyone.
Reply to Anonymous
- 0 +
Thanks much, Ben. I'm printing this out to try.
I went to HP.com/support and downloaded a "full" version instead
of the "basic" we probably all installed, (with dial-up it takes 20
hrs!) but need to increase my virtual memory by 412.92MB for a
gc_W01-EN (driver?) and I don't even want it if there isn't a
Twain driver in it.
I'll try your solution.
Reply to eagle1
- 0 +
of the "basic" we probably all installed, but need to increase
my virtual memory by 412.92MB for a gc_W01-EN (driver?) and I
don't want it if there isn't a Twain driver in it. I'll try to
contact them with a question.
Reply to eagle1
HP
TrayApp.
tells
> Any ideas?
> Thanks
> Gordon
Enyone, help!
Thanks Carla
Why would you just not uninstall hp products and reinstall them from the hp site? Is this not a simple fix?
Reply to Anonymous
There are 473 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
