Tom's Hardware Forums » Motherboards & Memory » General Motherboard » System hangs after changes to CMOS... HELP!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : System hangs after changes to CMOS... HELP!
Profile: stranger
More Information
Hiya guys. I seem to having an issue with a new PC that I can't seem to shake and was wondering if you have any suggestions.
The system specs are listed below. What happens is that everytime I make a change in the CMOS menu, save/quit; the system will just hang and never restart. Powering off the PS and system will not reset it. I must use the jumper to reset the CMOS. It will boot up with "CMOS checksum error - Default loaded" "Press F1 to continue, DEL to enter setup"
If I hit F1 to continue, it boots up without a problem and I can enter Windows 2000. I only have the video card, Promise RAID card, and sound card attached to the mobo. If I restart and reboot, the message screen where the [["CMOS checksum error - Default loaded" "Press F1 to continue, DEL to enter setup"]] appeared...would be replaced with "CPU is unworkable or has been changed. Please recheck - CPU SOFT MENU"
I already flashed the mobo to the last BIOS update and updated the Promise card drivers. Can anyone shed any light on this issue. Thanks in advance.
ABit Kx7-333
AMD 1900+
Crucial 512 DDR RAM
2 Seagate 40gig 7200RPM HDs
Promise TX2 100
SB Live! 5.1
VisonTek GeForce4
Acer 40X CD-ROM
Creative 8X DVD ROM
I found this on their website but it doesn't quit help as it just tells you how to reset it back to its default settings.
http://www.abit-usa.com/faq_letter0805.html
I doubt it can be a hardware related issue as I am able to use the PC just fine. Just can't save anything to the CMOS.
Related Pr oduct
Profile: Faithful Poster
More Information
Try replacing your mobo battery. You can get one at radio shack.
Profile: old hand
More Information
Try with a new battery, if it doesn't work just return the motherboard
<b>(<font color=yellow>as good as it looks</font color=yellow> )</b>
Profile: stranger
More Information
I suppose it could be the battery, but I wouldn't think so considering it will save the normal default settings just fine. Or am I assuming that they're not saved via battery as well?
<P ID="edit"><FONT SIZE=-1><EM>Edited by b4N4N4 on 09/15/02 08:44 PM.</EM></FONT></P>
Profile: stranger
More Information
Well, swapped out the battery and it problem still exists.
Add a reply
Google Ads
News
Lite-On Semiconductor to ship 1.3-megapixel CMOS-sensor modules
Published on February 01, 2005
Lite-On Semiconductor, a CMOS image-sensor and discrete-IC specialist, will begin volume shipments of its 1.3-megapixel CMOS image-sensor modules for camera-equipped mobile phones that use COB (chip-on-board) packaging, in April, according to the company. Read more
CMOS Image Sensor Makers Extend To Module Production
Published on March 25, 2008
Driven by attempts to shrink costs and enhance competitiveness, leading CMOS image sensor makers are said to extend their production from CMOS image sensors to module production, according to industry sources. Read more
Micron lays out 2005 projections for CMOS image sensors
Published on March 09, 2005
Farhad Rostamian, the strategic marketing director of Micron Technology, explained to DigiTimes in a recent interview how he believes that more applications are going to help boost demand for CMOS image sensors over the next three to four years. Read more
Latest Reviews & Articles
Shuttle's X27: Can Atom Handle Vista?
Published on October 08, 2008
In the horsepower race between Intel’s and AMD’s quad-core chips, the Atom processor is an everyday hybrid. Shuttle took it and created a pint-sized small for factor box. Is it powerful enough to be your daily-use desktop, though? Read more
Do New Drivers Really Boost Performance?
Published on October 07, 2008
How much extra performance can you get from a simple graphics driver update? And what sort of gaming gains can you expect from a high-end graphics card when you overclock your CPU? Read more
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
