Ok, I bought a new Enermax box, and I am very used to seeing the LED connectors and switches together on one plastic pin. Ie, I have an Antec case, and I have a five pin connector called "Speaker" and a two pin called "power switch" right on the plastic connector the wires go into.
On this new case each wire has it's own plastic connector, and cryptically titled.
I need help with figuring the below out:
I have a four pin connector, again all seperate plastic connectors. I think since there are 4, it is the Power LED and Power Switch. I then have a five pin connector, which I believe is the HDD LED and Reset Switch
Four Pin title on each plastic connector (each "1" has a circle around it):
1 Ground (black sleeve)
1 +5V (red sleeve)
1 +D (green sleeve)
1 -D (white sleeve)
Five Pin title on each plastic connector (each "2" has a circle around it):
2 Shield (dull black sleeve)
2 Ground (shiny black sleeve)
2 +5V (red sleeve)
2 +D (green sleeve)
2 -D (white sleeve)
The four pin indicates (JFP1) the following on my MOBO wich is a MSI K7T266 Pro2-A
Pin 2: FP PWR/SLP - MSG LED pull up
Pin 4: FP PWR/SLP - MSG LED Pull up
Pin 6: PWER_SW_P - Power Switch high reference pull up
Pin 8: PWER_SW_N - Power Switch low reference pull down to GND
The Five pin (JFP1) indicates:
Pin 1: HD_LED_P - Hard Disk LED pull-up
Pin 3: HD_LED_N - Hard Disk active LED
Pin 5: RST_SW_N - Reset Switch low reference pull-down to GND
Pin 7: RST_SW_P - Reset Switch High Reference pull-up
Pin 9: RSVD_DNU - Reserved. Do not use.
So my friends, please tell me what connector goes to what pin
(ie:
Four Pin
1 Ground (black sleeve) = Pin 8
though I am guessing, this is just an example..)
The mobo manual also says something about "Intel Front Panel I/O Connectivety Design Guide" compliant.
Thanks everyone!! =)
1 +5V (red sleeve)
1 +D (green sleeve)
1 -D (white sleeve)
2 +5V (red sleeve)
2 +D (green sleeve)
2 -D (white sleeve)
(ie:
Four Pin
