I purchased a antec true power supply 430 watt on 9/21/2002.
I installed it in a Antec case model # SX-830.
I have a Soyo SY-K7V Dragon Plus motherboard with a AMD XP 1700 chip.
The system worked fine with the existing 300 watt power supply that came with the case.
I was planning to purchase a new video card that required a 350 watt power supply so I purchased the new power supply.
When I installed the 430 watt power supply it caused the following problem.
During the process of a clean install of XP the computer would lock up during hardware detection.
It did not and still does not do this with the 300 watt power supply.
I was able to recover from the lockup and finish installing xp
When trying to install drivers for a Creative labs Audigy sound card the computer would lock up.
I could install the driver for all other devices but the Sound blaster card.
I went back and installed the 300 watt power supply and the Sound blaster drivers installed perfectly with no lock up.
I then performed a clean install again with the old power supply and experienced no problems. I continued to install all drivers to my components with no problems what so ever.
I then tried installing the new power supply again.
When windows booted up it locked up and there was a ear piercing screaming sound from my speakers.
I pulled out the sound blaster and the computer booted up fine.
I then put the old power supply back in and the sound blaster and had no problem.
I exchanged the new power supply with another but I had the same problem with it as well.
Can you help me?
Brian Knapp
<P ID="edit"><FONT SIZE=-1><EM>Edited by quintus on 09/30/02 10:08 PM.</EM></FONT></P>
Can you help me?
Brian Knapp
