Tom's Hardware > Forum > Games General > PC Gaming > Low fps problem
Low fps problem
Forum Games General : PC Gaming - Low fps problem
Im having a weird problem that i cant figure out,my ping is alwalys low and my fps is usually 30-60 while playing battlefield 2142 or cs,but no matter what i do it drops out of no were to 10 and stays there for a little bit then goes back to normal and back down again.It dosnt matter if the details are onhigh or low,or if the aa is changed.My laptop used to run perfectly and it never lagged,but recently my fps has been going crazy.And im postive nothing is running in the background,and theres no virus or anything like that.
Hp pavillion 9000
windows xp,1 gig of ram,
Nvidia geforce go 6150,256 mb
3.2 processor
Any ideas why this is happening?
Sponsored Links
I really dont think you have enough RAM in your system to run BF2142 smoothly... If there is anyway to try out more memory do so and see the resaults.
------------------------------ "Great spirits have always found violent opposition from mediocrities. The latter cannot understand it when a man does not thoughtlessly submit to hereditary prejudices but honestly and courageously uses his intelligence."
Reply to cafuddled
- 0 +
Try adjusting your windows swap file. Maybe this helps your problem. By putting it from the windows default settings to 1536 min and max.
Hopefully this helps.
------------------------------ Desktop: AMD Athlon 4200+ (2,66Ghz), 2GB DDR, Ati Radeon HD3870, Samsung Syncmaster 19" 931bw | Windows 7 build 7600 x64 (RTM)
Notebook: Intel Centrino T8100 (2,1Ghz), 4GB DDR2-667, Ati Radeon Mobility HD3470 | Windows 7 build 7600 x64 (RTM)
Reply to FeareX
Turn off all apps that don't need to be running. Anything that is running and doesn't will take up what memory you have and slow your system down. You could also try a fresh install of XP.
------------------------------ LAPTOP: Sager NP5760|T7200|2gb DDR2-667| 100gb 7200rpm HDD| 512mb 7950GTX|17'' WUXGA
Desktop: Core2 E7200 | Corsair 2gb DDR2-800 | Gigabyte EP35-DS3L | 250gb Seagate Barracuda | MSI GTX260 (192 SP) | Corsair VX550 | Antec 300 case
Reply to lostandwandering
2 Gb of ram fixed the same problem I had in BF 2 and you should have 2gb anyhow now days if your a true gamer.
------------------------------ Phen 2 955 @ 4 GHZ MSI 790FX AM3 Gskill 8Gb DDR3 1333 ATI 5870 1 Gb 2 x Velociraptors 600Gb Gateway 24" 1920 x 1200 DVI 32 GB Iphone 3GS and Blu Ray...life is good!
Reply to soldier37
There are 986 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
