Laptop power options
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Hi All
Just bought a laptop to use in the car for GPS, which is working great. The
problem is as I'm driving, the laptop shuts down and I have to log back on.
I've set the Power Options in the control panel. The "Enable hibernation"
box is not enabled, the "prompt for password" is not enabled, and all power
schemes are set to "never". I checked the bios settings for power management
settings, and found none. Is there a way to disable these settings in the
registry, or any other place?
Thanks
Harold
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.735 / Virus Database: 489 - Release Date: 8/6/2004
3 answers Last reply
More about laptop power options
  1. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    If you just bought the laptop, it is under warranty. Have you checked with the
    vendor or the manufacturer's website/or 800 number what could be the cause
    of the shutdowns?
    "Harold Druss" wrote:
    > Hi All
    > Thanks
    > Harold
  2. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Hi,
    Goto the desktop option by right clicking on the desktop and goto screen
    saver option and check wether it is set to none. becasue sometime if it is
    selected and the option of display welcome screen on resume might cause the
    same effect as you said.
    Hope this helps you.
    Regards
    Ravickumar M
    "Harold Druss" <hdruss@worldnet.att.net> wrote in message
    news:IV0Tc.203762$OB3.68221@bgtnsc05-news.ops.worldnet.att.net...
    > Hi All
    The
    on.
    power
    management
    > Thanks
    > Harold
  3. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Hi Ravickumar M
    That's exactly what it was. Now why didn't I think of that!
    Thank you so much.
    Harold
    "Ravickumar M - MVP" <magicravi@msn.com> wrote in message
    news:OCTEd0UgEHA.2764@TK2MSFTNGP11.phx.gbl...
    > Hi,
    the
    > Regards
    > Ravickumar M
    > > Hi All
    > The
    > on.
    hibernation"
    > power
    > management
    the
    > > Thanks
    > > Harold
Laptops Power Windows XP
