Ok, I just installed GRAW2 and it's gorgeous! I love everything about the single-player game and I haven't gotten to play multi-player yet. Here's my problem... at the end of mission #2, the score screen comes up and the only option that I have to click on at the bottom is "Return to Menu". The "Next Mission" button is completely gone! When I click on the return to menu choice, it returns me back to the mission selection menu and doesn't advance into the next mission.
Is this a resolution issue (I'm at 1680x1050), where the score screen is messed up? The reason why I ask this is because at the end of the first mission, the two choices at the bottom of the score screen were overlapping on screen and I had to position my mouse VERY carefully over an area of about 5 pixels in order to get the "next mission" selection to highlight.
I've patched to 1.02 and it still hasn't fixed anything. HELP!!!!
The solution:
Download a finished savegame and put it in your save games folder. If you can't find an savegame just PM me and ill send you mine over MSN or something.
------------------------------Desktop: AMD Athlon 4200+ (2,66Ghz), 2GB DDR, Ati Radeon HD3870, Samsung Syncmaster 19" 931bw | Windows 7 build 7600 x64 (RTM)
Notebook: Intel Centrino T8100 (2,1Ghz), 4GB DDR2-667, Ati Radeon Mobility HD3470 | Windows 7 build 7600 x64 (RTM)
Reply to FeareX
I actually figured this out. When you click on CAMPAIGN from the main menu, you have to click CONTINUE, not LOAD SAVED GAME if you load the saved game, it turns the game into a single-play mission instead of the campaign version. It's crap, because I think that if you LOAD a campaign saved game, it should stay in the campaign mode. Anyway, hopefully this helps others.
BTW: just for anyone considering getting this game: DO IT! I can't rave enough about the single-player portion of the game. It's completely gorgeous to the eye and plays nicely on a non-bleeding edge systems. Interface is good (takes some time to get used to, but once you do, it's ON!) and the AI is definately a little lacking... (when is that NOT the case???), but completely playable. The bots do flank and go completely around your area to get you from the back, so it's got some edge to it. I say give it a shot and you won't be disappointed.
