I put this system togeather over a year ago, thanks in part to THG, it has running fine sense then. Yesterday i opened up the case for a dust cleaning i thought it wa due for... so i took of the CPU HS and took it outside and sprayed all of the dust off of it. I also took out the CPU (athlon 1.2) and cleaned all of the AC2 off of it. I put some AC2 back on, and stuck the HS back on, put the memory i had taken out (was blocking the HS clip) back in, power on, and was getting beep errors. I checked the memory was in all the way, which it was, Rebooted, same errors. I looked up the errors in my mobo manual, and they listened them as either Broken or Miseated DRAM or Overheated CPU resulting in the system running at a lower clock speed.
Today i took my ram down to a local shop, and asked them to test my DIMM, they did, and they said it worked fine. I cannot figure out why i get this horribly annoying beep. I plan on calling ASUS tech support as soon as i can. I would like any ideas anyone has about this problem.
For now, i'm stuck on the machine i use for listening to streaming radio, a pentium 100mhz with 32mb of ram. HELP!!
<font color=green>I can draw tyte give me the damn crayon!</font color=green>
