I've had trouble with BS on Vista. What OS are you using? Running Vista in "XP SP2 compatability" mode solved the sound issues for me.
In addition to sound problems the game crashed frequently on startup and lost all custom setting as well. I switched off the "Aero" interface in favor of "Basic" and now the game starts quicker and has not crashed since I made the change.
The games seems to be running solid now. Time will tell, I only made the changes yesterday.
BS is a pretty darn cool game once it is running good.
Right Click the Program Icon, properties - Select the Compatibility Mode tab in th epop up menu, click the checkbox in the top/center. then use the Drop Down to choose which mode.
------------------------------Being requested to remove my siggy implying some people here would receive greater personal benefit from a local Prostitute than from a new GPU in no way, shape, or form changes the aforementioned opinion.
Reply to Scotteq
I know it's been a while since this forum was open, but i'm facing the same problem. The sound works just fine until the crash and the Bioshock "logo" disappears. I currently have the beta version of windows 7, do you think that this could be the issue.
i have windows vista 64 bit
6 gb ram
600 gb hard drive
pentium dual core processors
geforce 8600 video card
running the downloaded version
the game menu and first video had sound but one the bioshock sign came up with the water dripping off of it the sound stopped. all drivers are updated. i tried switching the compatibility to windows xp sp2 and the sound started to work but now the game is windowed and the edges get cut off.
who have real tek on board ?
so in windows vistas (64) goto /start /konfigu /sound /record /stereomix /enebel /.
in game go to /
opsions / sound /use reverb off /use creative eax off audio /than restard. game.
ok and vga is ....
vga / turn win background to ( 1024x768.depends of jour pc) to 16 bits .
in the game in enything jou wand end kan do whit jour pc .
sorry vor my poor lengwitsh ha ha lol .
i hoope enywan have some good ad this .
my pc con fig is .....
aser aspire whit a/ i7 procecor / 6 ghz onboard memddr3 /1ghrdati radeon ddr3 vga / and / 1000gig hd /for me it workt !!.
so i hoope eny wan have somthing from this .afz dre
Hi Lakedude
I am currently running Win7 RC 64bit and also had the same sound issue, As soon as the plane crashed my soud went dead.
I installed windows virtual pc and virtual windows win xp. I installed the game on the virtual pc and placed the shortcut in the program files open to all users.
All I get is "Bioshock cannot be launched from a remote session".
How did you get it to work or have I done it wrong?
Note: I purchased the game through steam. I dont know if this makes any difference.
Hey Everone, I found a solution that at least worked for me, i was having the same issue that everyone else is posting with no sound for bioshock. it sounds weird but all i had to do to fix the issue is plug something into my microphone port. i just plugged a pair of headphones into it and it the sound starting working. sounds strange but it worked for me. hope this helps someone.
Hy, this is a copy from another forum, its work for me
.....Open start, than Controll panel, Sound, Than recording( My OS is set to norwegian so i don't know exactly the name of the menu, but it is the one in the middle and it has options with recording) In the recording window there will be a few options, right-click in the background of the window and press "Show offline units" (again i have norwegian OS don't know exactly what it says" press "Show offline units and you will have a new option called something like Stereo Mix. Enable Stereo Mix, and hopefully it will work.....
Does anyone have any tips?
NTG,
i too have windows 7 RC and had the same sound issue. i tired starting the game with Xp SP2 but then it wouldnt start at all. did you find a solution?
