Tom's Hardware > Forum > Games General > PC Gaming > Power Supply Question
Forum Games General : PC Gaming - Power Supply Question
I recently formatted my system, and installed all of the latest drivers. I run an AMD X2 3800+ , 2 gigs DDR400 Ram, an 8800GTS 320mb and Windows XP. I get absolutely horrible framerates, in the crysis beta I never get over 20 fps while running medium settings on 1024x768. As well as in Bioshock, Counter Strike Source, and Medal of honor Airborne I am getting low FPS.
I got to thinking, I only have a 400w PSU, could this be the issue? Could a PSU be the cause of low performance for a system that is decently mid - high end?
Any thoughts?
Thanks.
Sponsored Links
It could very well be the cause, could you get something else than the wattage (Which is as good as nothing)? we need brand, model, and 12V ratings to be able to tell.
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
One moment while I open the case to determine this.
Reply to w0107257
Brand = Codegen
Model = 350X
12V = 9.6W
Reply to w0107257
bump
anyone able to help?
Reply to w0107257
- 0 +
That thing can never power a GTS properly, you are lucky that the system even boots up. Try a high quality, powerful unit like this instead:
Antec NeoPower NeoHE 550 ATX12V 550W Power Supply 100 - 240 V UL, CUL, TUV, CE, FCC, CCC, CB, C-tick - Retail
http://www.newegg.com/Product/Prod [...] eohe%2b550
This unit can output 42A on the 12V+ rails, there's no single card setup that this unit can't power up, so you'll be fine for a long time to come.
www.lucidlogix.com
Reply to emp
There are 822 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
