Yes No
Ads
Tom's Hardware > Forum > Computer Brands > HP > HP C360 power supply broken?
Forum Computer Brands : HP HP C360 power supply broken?
Archived from groups: comp.sys.hp.hardware,comp.sys.hp.misc (More info?)
Hello,
we have a couple of HP C360 still working. One of them stopped last
week when I was away. Now it does not react on the power switch any
longer. There is no indication the system receives any power
whatsoever.
Of course I changed powercords and made shure there is power on the
plug, that changed nothing. Taking the machine appart and refitting it
(well, it sometimes helps with computers) also made no
difference. There is absolutely no reaction to the powerswitch.
I am afraid the power supply is broken. It gets warm although nothing
else happens in the machine. Is it possible to buy replacement ones?
Any idea as to what might have gone wrong or what I could do next?
Thanks in advance
Hinnerk
PS: X-post and F'up
Dr.-Ing. Dipl.-Inf. H. Hagenah hg@lft.uni-erlangen.de
Lehrstuhl fuer Fertigungstechnologie FAU Erlangen
Life's most persistent and urgent question is, What are you doing for others?
(Martin Luther King Jr.)
Reply to Anonymous
Archived from groups: comp.sys.hp.hardware (More info?)
> although nothing else happens in the machine. Is it
Well, since it gets warm, maybe it's still
functional but the interruptor is broken.
It happened to my PC's power supply, too,
and it took less than half an hour for a
generic electrician to open it, change the
interruptor and bring it back to life.
HTH
Villi
Reply to Anonymous
Hello !
> Hello,
> whatsoever.
Do you hear the fans ?
I had the a problem with a C240 powersupply, too. Take out power cord
for a day, and refiting (sometime I need a lot of refiting) - it helped
at my C240. But with these failure in the power supply you should not
take out the power supply.... ;-)
But the Cxxx have a problem with the power switch too. Search at
docs.hp.com and itrc.hp.com for some informations. There are some
documents for troubleshooting these power switch/supply failures.
HP (CRC Ratingen) could help you. There you can order a power supply or
switch unit too.
Or look for refurbished power supply/switch from a other company.
Bye
Lars
Reply to Anonymous
You might check partsurfer.hp.com
When I was still doing regular stuff with C240's and the rest of the
workstations that slid in and out of the box like a drawer, there
would be times when I slid the stuff back-in, but it dind't seat quite
right for the power interlock. Reseating the system board - slide it
out, and slide it back-in firmly, coupled with making sure the screws
were installed often sorted the problems I was having. Perhaps it
will help with yours.
hth,
rick jones
a wide gulf separates "what if" from "if only"
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to raj in cup.hp.com but NOT BOTH...
Reply to Anonymous
Lars Bausch <lars.bausch@dotsch.de> writes:
> > whatsoever.
No, there is absolutely nothing to hear. No sign of life or reaction
on pushing the power-switch.
Although I have no idea how this should help I'll shure give it a
try. I took the damn thing appart yesterday but remounting didn't
help...
OK - but searching there isn't too easy.
Thanks
Hinnerk
Demokratie ist die Staatsform, die keiner mitbekommt, wenn sie nicht fehlt.
Elmar Kupke (*1942), deutscher Aphoristiker und Stadtphilosoph
Reply to Anonymous
Rick Jones <foo@bar.baz.invalid> writes:
Hm - makes me wonder how things can losen up when the machine is just
sitting under the table. I should be the only one touching those
screws around here... I'll give it a try anyhow.
Thanks
Hinnerk
Reply to Anonymous
> whatsoever.
We've seen around a dozen fail this way, they work fne until you unplug
them then they won't restart. It's never the internal fuse, new psu time
Who needs a life when you've got Unix? :-)
Email: john@unixnerd.demon.co.uk, John G.Burns B.Eng, Bonny Scotland
Web : http://www.unixnerd.demon.co.uk - The Ultimate BMW Homepage!
Need Sun or HP Unix kit? http://www.unixnerd.demon.co.uk/unix.html
Reply to Anonymous
There are 2267 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 9 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
