Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Cable broadband vs Wireless advice needed
Forum Wireless Networking : Wireless General Discussions - Cable broadband vs Wireless advice needed
Archived from groups: alt.internet.wireless (More info?)
Hello all
I just signed up for Comcast broadband cable internet
service at a new house I'm moving into.
My question: I have a Linksys 804G Cable Modem with
built-in wireless router and 4 port wired router.
Should I FIRST hook up a computer and configure the
ISP and get it running 'hard wired' first? Or should I
configure the wireless LAN FIRST - getting the computer
first to talk to the router before I hook up the cable and
run the Comcast software?
Or does it matter either way?
Thanks - any advice appreciated
Dave
devarim at hotmail dot com
Sponsored Links
"Dave" <Devarim@hotmail.com> wrote in message
news:1aa042456c05c32d03761f6a48f96ff9@news.meganetnews.com...
> Hello all
> Dave
The cable company will undoubtedly want you to hook up the cable modem with
a single computer first. My cable company, CableVision Optimum Online, will
only troubleshoot with me on the phone if I remove the router. They don't
object to my using a router day-to-day; they just won't troubleshoot with
it.
With my 3Com cable modem, the modem remembers the MAC address of the device
that's hooked up to the customer side. So when I switch from a cable
modem-to-router connection to a cable modem-to-computer connection, I must
power off the cable modem for at least one minute to make it forget the MAC
address.
You mention some Comcast software. You may not need it. I never use cable
company software. If you do want to use it, you'll have to do that on a
computer; the router won't run it.
In short, you can set up the LAN first and hook the router to the cable
modem if you like. But you may want to know that the cable modem works with
just a computer so that you won't be doing it for the first time when the
cable company asks you to.
Ron Bandes, CCNP, CTT+, etc.
Reply to Anonymous
- 0 +
with
Thanks Ron - in the meantime I simply called Tech Support at Comcast, and
they said exactly what you did. And no, the software isn't needed unless I
want
to use USB (which I won't). I just need to call them to register my MAC
address
of my modem, and establish DHCP and a TCP/IP connection. Then I'm set.
Again, thanks for the confirmation.
Dave
Reply to Dave
Don't install the comcast software!
Also, you'll want to configure your router by ethernet because it is
difficult to configure wireless security settings when connected wirelessly
(you'll want to turn on WPA-PSK encryption).
-Yves
"Dave" <devarim@hotmail.com> wrote in message
news:f75c45b5b8704fa935a459ccfbedf6f0@news.meganetnews.com...
> with
the
I
> want
> address
> Dave
Reply to Anonymous
He said that the cable modem had a built in router, so that wouldn't apply.
Otherwise, the restriction varies by cable system. My Mediacom requires
that the MAC of my PC/router be registered with them. If you connect a PC
directly, this is obvious. Open a browser and it connects to a page that
says you need to register. If you connect through a router, that window
never appears, you just can't connect to the internet.
You can either register your router by phone, or use the "Clone Mac" option
to copy the MAC of the PC used to make the connection originally.
For Cable, the only PC-installed software I've heard of is USB drivers if
you want to use the USB modem port instead of the ethernet port.
That makes it sound like it is a separate modem and router.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
Reply to Anonymous
There are 1249 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Foxer57 won the Uniformed badge
  • 01:00 gregmo won the Freshman badge
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
