Thank you for taking the time to reply! I am looking for a system around $500.00. I have all the other components. I am an avid or amateur builder. I really only want a processor, fan, and motherboard, and possibly a case to put it in. I have the other pieces. I'll take them out of my current system.
Thank you for the SDRAM and DDR RAM explanation. It helped me out greatly! I will definately check out the DDR RAM and forgo my SDRAM.
I heard people talk about ABUS and ASUS I think, I'm not sure. I am so bad at this stuff.
I want a system that will last me for 3 more years. I want something that I can play DAoC on, a gaming system, played over the 'net as a MMORPH (www.darkageofcamelot.com) So when I get into battles I want to be able to handle the lag when others come into view and their information is stored or loaded onto my system. I have a DSL connection so I am not too worried about lag from the network. I basically want to put some cash into the system upfront, and get a system around 2.5-2.8, something good that will last me a good while like my PII 400, which has lasted me a good long while.
I was looking to get a system that was bundled together, a barebones system with the 3 components all together, but I will DEFINATLEY check out what you mentioned and give it a whirl!
Thank you!
