Ok, I'm not as clueless as the title makes me sound.
Here is the problem.
I have a k7sva board with an atlon 1700+ proc, and in the cmos both the ram and cpu multiplier are set tp 100 and the clock shows 1100mhz, when I change it to 133 (it will allow me to do it 3 ways, ram 133/100, ram/cpu 133/133, ram/cpu 100/100) Anyway when I set it to 133/133 it shows the athlon 1700+ properly and makes it to the point where windows xp starts to load and then locks up.
I'm using 512 of pc133 ram also if that helps.
What do I need to do?
Thanks for all the help in advance
