Yes No
Ads
Tom's Hardware > Forum > Video Games > PC Gaming > BF2142 resolution problem
Forum Video Games : PC Gaming BF2142 resolution problem
For some reason, I can only play BF 2142 in 1024 X 768. Why can't I play in 1280 X 1024? Is there somewhere I can change the resolution other than in the game (like in a config file)? I have looked for one but can't find it.
------------------------------ GA-890GPA-UD3H | 1090T @ 4.0 Ghz @ 1.44v (load)| Xigmatek Gaia | 4GB OCZ Reaper 7-8-9-22 1T @ 1577 Mhz | Samsung Spinponit F3 HD103SJ 1TB | PNY GTS 250 789/1221 | Corsair CMPSU-650TX
Reply to jedi940
UPDATE, I just found the config file in the
c:\Documents and Settings\Username\My Documents\Battlefield 2142\Profiles\Default\video.con
I changed it from 1024x768@75Hz to 1280x1024@75Hz and the game won't load. the screen goes black as though it is going to but then it just quits and I am back to the desktop. Is there anything else I can do to up the resolution.
By the way, I can play Battlefield 2 at 1280x1024 with 8xAA just fine. It is not a hardware problem the option just doesn't show up in the settings.
Reply to jedi940
- 0 +
I can only play 2142 @ 1280x960 and BF2 @ 1280x1024, it's retarded, DICE won't allow wide screen resolutions.
------------------------------ Yep, I was here before Al Gore invented the internets.
Reply to stemnin
- 0 +
But i don't want to play in a wide screen resolution. I want to play in the standard 1289x1024. I found it odd that I can in BF2 but not in 2142. THey are made by the same company!!! I still think there has to be a way to work around it. I just haven't found it yet. I was hoping someone else here has.
Reply to jedi940
- 0 +
Yeah, it's messed up.
Reply to stemnin
I think it's because most CRT monitors don't run in 1280x1024 but in 1280x960, I've had that issue in other games just drop it slightly to 960.
Reply to spanner_razor
- 0 +
I've never seen a CRT that has that native res, ever lol, must be a euro thing.
Reply to stemnin
- 0 +
What are you talking about? all CRT monitors will run in 1280x1024. That is the standard format resolution. I have three that will. However this is irrelavant to my problem because I have an LCD screen with a native resolution of 1280x1024.
Reply to jedi940
- 0 +
Are you replying to me or the guy i was replying too? (i'm saying i've never seen a CRT display with a native res of 1280x960)
Reply to stemnin
I like to play in widescreen, which BF2142 doesn't support. The way around this is to change the shortcut settings. Right click on the game icon, go into properties. The target will be C:\Program Files\Electronic Arts\Battlefield 2142\BF2142.exe" +menu 1 +fullscreen 1 . You can define the resolution by adding +szx 1280 +szy 1024 (or your preferred resolution settings) to the end of the target, and you can change to widescreen by changing +fullscreen 1 to +widescreen 1. If you want to change the resolution to 1280x1024 the target should look like this:
C:\Program Files\Electronic Arts\Battlefield 2142\BF2142.exe" +menu 1 +fullscreen 1 +szx 1280 +szy 1024
Be aware that if you don't use the shortcut (ie you click "start game" when the popup appears after inserting the disc) you won't get the specified resolution, or you may get the black screen. Otherwise this will work. Good luck.
------------------------------ Intel Core i5 2500/ 8gb Patriot 1600mhz/ MSI P67A-GD65/ WDC Black 750 gb/ Radeon HD 4870/ 600w Antec Noisetaker/ Antec 900
Reply to KekaiGenkai
- 0 +
@ KekaiGenkai - Thanks for the info. I'll try it tomorrow.
@ Stemin - I agree with you, my reply was to Spanner_razor.
Reply to jedi940
There are 2202 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I like this game a lot it is FIFA street 2?
By hairystuff, 6 hours ago:
if its a pirate copy then no one will help here
Best offers
Top experts
