Tom's Hardware > Forum > Games General > PC Gaming > BF1942 problems
BF1942 problems
Forum Games General : PC Gaming - BF1942 problems
I am trying to put BF1942 on my friends computer and it won't run. everytime i start the program, I see the splash screen and the screen goes dark as if it is starting and then it quits and I hear the default sound for windows causing an error. I have already updated the game to most current version so i don't think that is the problem. I am leaning toward it not liking the non legal version of windows. Any thoughts???
SPecs
2.6 celeron
fx5200
640 mb DDR266
xp pro cracked version
DX 8.1
------------------------------ GA-965P-DS3 (rev. 3.3) | e6600 @ 3.4 Ghz 425x8 @ 1.42v | Thermalright Ultra 120 Extreme | 2GB Corsair XMS2 4-4-4-12 @ 850 Mhz | 2x160GB WD Raid 0 | 2x250GB Segate Raid 1 | evga 8800GTS 320mb 580/1840 | OCZ 700W PSU | 3dMark06 10346 @ 1280 X 1024
Sponsored Links
Do you have the 1.6.19 patch installed?
also set your desktop resolution to 800x600
start game, set in game resolution to what you want
then set desktop resolution back to whatever it was
also try here for other tips/tweaks http://www.tweaktown.com/guides/42 [...] index.html
Reply to n3zyd
I play 1942 quite a bit on several of my machines. I loaded it on my laptop and it worked fine BUT all of a sudden it stopped working on my laptop. I would doubleclick the icon it would start to load then blow me back to the desktop. I assumed I must have changed something in the configuration of my laptop for this to happen but it is still a mystery. I have re-installed the game twice, tried patching it, tried changing my video drivers, tried editing one of the .con files in BF1942, tried adding another gig of ram to the laptop. To this day it still won't run on it but it use to!
By the way my version of Windows XP is legit so I don't it has anything to do with that issue.
Reply to anthemmobil1
- 0 +
Do you have BF2 or BF2 demo or BF2142/Demo installed on the laptop?
On my comp I had BF1942 then put BF2 on, Deleted BF1942 and BF2 stopped working.
After many forum searches found out the two games somehow share some files that when you delete one it borks the other.
Reply to n3zyd
I'd say the FX5200 is the issue. Its a little week for that came. I loaded it on my laptop 1.4GHz M/ 512MB RAM/ 9600 Mobility. It will run with everything on LOW but is choppy and really isn't playable anyways. Plus your are using a Celeron. My opinion is it is a weak system for this game. You might want to try 800x600.
ALSO if it is dying on the intro video, try renaming the file with that video in. I did this so it just jumps right to the BF2142 login screen and I don't have to watch that crap.
------------------------------ Big Brother Rules with an Iron Fist
Reply to jay2tall
- 0 +
It can't be the "weak" card because I am trying to run battlefield 1942. The game came out before the fx5200 card even existed.
I will try the 800x600 res. I did install the patch. It didn't work before or after the patch was installed. I installed it from a copy of the original cds so the original try was with version 1.0
As for the copy of xp. we are working on geting a legit copy. the version I have is pretty buggy anyways. It is only a temp solution.
Anthemmobil1 - I am having the exact same problem as you seem to be except that it never worked for me :(
Message edited by Jedi940 on 11-16-2007 at 04:22:38 PM
Reply to Jedi940
- 0 +
I just tried the 800x600 res and that didn't help. Any other suggestions?
Reply to Jedi940
- 0 +
Well, I figured out the problem. I needed to update Direct x. Now I just have to get him a new graphics card. That fx5200 won't even run the game on 640x480 at low resolution. Luckily I have a spare radeon 7500 lying around. That will work much better. Thanks for all your help and suggestions.
Reply to Jedi940
There are 1261 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
