"SetConfig Application" problem.
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I receive a SetConfig Application box randomly during boot or during use. As
far as I can tell the machine works normally regardless of whether I receive
the box or not. I have sent this problem to MS as requested in the box. I
have two questions:
1). Is this a serious problem?
2). If the answer to 1). is "No" then how do I prevent this message box
appearing?
Peter.
G
Guest
Guest
The machine is a HP Pavilion/Athlon/XP. It is on a 3 PC home network via
wireless connection.
Peter.
"PVR" <peterv666@adelphia.net> wrote in message
news:Ld2dnfPjUYnCyd3cRVn-hA@adelphia.com...
>As far as I can tell the machine works normally regardless of whether I
>receive the box or not. I have sent this problem to MS as requested in the
>box. I have two questions:
> appearing?
> Peter.
dilbert
44
I've read in a couple of places that it may be to do with printers and
printer drivers.
Particulary HP. I'm going to uninstall the printer from a problem PC when I
get back to work on monday ... fingers crossed it gets rid of the problem
> Peter.
> > appearing?
> > Peter.
G
Guest
Guest
Interesting. My PC is part of a home network but no printer is attached to
it. Four printers are attached to my home office PC (XP) and I use those for
my printing needs. I have not had any "Setconfig" problems with the office
PC.
After receiving your answer I tried the MS KnowledgeBase. No mention of
Setconfig. I tried the MS newsgroups without luck. I hit Google and received
three hits, all in a foreign language (Norwegian).
At the moment I am not aware that this situation is causing me any problem
other than irritation. If uninstalling your driver helps I would appreciate
an email.
Peter.
----- Original Message -----
From: "Dilbert" <Dilbert@discussions.microsoft.com>
Newsgroups: microsoft.public.windowsxp.newusers
Sent: Saturday, September 11, 2004 5:49 PM
Subject: Re: "SetConfig Application" problem.
> printer drivers.
> I
>> Peter.
"Dilbert" <Dilbert@discussions.microsoft.com> wrote in message
news:09DA1F4B-56A0-4C6F-8495-C1CF6DE67089@microsoft.com...
> printer drivers.
> I
>> Peter.
>> >use.
>> >the
>> > appearing?
>> > Peter.
dilbert
44
I've uninstalled the printer drivers and it does seem to have cured the
irritation.
I'll worry about reinstalling a printer on that machine when a user
complains they can't print !!
I just want to check that the problem has gone away first.
Both printers installed were HP, one was a laserjet 1300 the other was an
all-in-one ... can't recall the model no.
I'll post after i reinstall one of them to keep you updated.
> PC.
> an email.
> Peter.
> > printer drivers.
> > I
> >> Peter.
> > printer drivers.
> > I
> >> Peter.
> >> >use.
> >> >the
> >> > appearing?
> >> > Peter.
