Hello. I built a PC with the MSI KT7266 Pro2-RU motherboard and an Athlon XP 2400+ and it won't even do a POST. I turn it on, all the LED's are red, there is no display and it's just the fans and hard drive running. At first I thought it needed a BIOS upgraded, so I took an Athlon 1200 to boot it up and flashed the BIOS. The upgrade did not work. (At least I found that the motherboard and all my connections and jumpers were okay.) I reset the BIOS. I've tried everything already.
At first I thought the CPU was dead, but when I tried it in another motherboard, an MSI KT7266 Pro2-A, and it worked... although the BIOS reported it as an 1800+.
Is there an issue between the 2400+ and the Pro2-RU? Is there a way to fix it? Thanks.
