Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Just finished downloading Windows XP Home critical updates, to find that I no
longer get pictures...instead I have little white boxes with coloured shapes
inside. Can anyone tell me how to prevent this happening again and how to
revert to pictures?
Thanks in anticipation.
Sponsored Links
> that I no longer get pictures...instead I have little white boxes
> with coloured shapes inside. Can anyone tell me how to prevent this
> happening again and how to revert to pictures?
Alisona
OK, I'll take the first guess. Outlook Express? Go to tools/Options/Security
tab and remove the check mark from the Block Images option.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
Reply to Anonymous
> Alisona
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
> Thanks for your help Ronnie,first guess correct, sorry for lack of useful info. Did as you suggested, the box required to be unticked but it has made no difference. I dont use outlook express...is this a problem? I use msn for mail and as home page. Internet Explorer not used very often either, tend to do all via msn. Any otherinfo required? Can you suggest any other boxes that might help? V.sad person...am missing my butterfly not to mention the mess it makes of eBay. Thanks again. alisona.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > post Update Problem
There are 1320 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
