Archived from groups: comp.sys.hp.hardware (More info?)
What is a simple way to check the functioning of a sound card? I have a hp
pavilion 6730 and all audio except for playing cds has gone totally caput for
my pc.
hi,
go to http://www.driverguide.com do a simple search for 4299vxd. these are drivers that work for a
pavilion 6730 crystal audio card .
hope this helps,
terry
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
hi,
i should have mentioned that you would need to register and then log
in .
the page that opens when you log in has a list of different searchs
under the word drivers on the left margin .
hope this helps,
terry
Sorry to be a pest ..but,
When I try to run the driverguide toolkit program after fully downloading i
experience the windows errors,
The c:\windows\desktop\dgt.exe file appears to be corrupt. Reinstall the file,
and then try again. | Windows cannot run this program because it is in an
invalid format.
hi,
i have had great results with belarc advisor available at
http://www.belarc.com it is a utility that lists the hardware and software on your computer
i suggested the 4299vxd.zip because it works on my pavilion 6730
running 98se . do you have the recoverey disk set ? if not they are
available at http://www.dewaldsr.com .
hope this helps,
terry
>hi,
>hope this helps,
>terry
Would the recovery disk set help determine if my sound card was working..??...
william,
go to http://www.infohq.com/Computer/com [...] d-help.htm they have the instructions for testing your sound in windows and
checking if the device is installed in device manager . most of the
problems i have had with sound cards were driver related . i
mentioned the recovery disks because they have all the original
drivers as well as the software that came with your system when it
was new .
hope this helps,
terry
>william,
>go to http://www.infohq.com/Computer/com [...] d-help.htm >they have the instructions for testing your sound in windows and
>was new .
I tried the link but as far as I know a sound card is installed from viewing
device manager. Is this not the device listed as "crystal wdm audio codec"?
