Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
David wrote:
> In Win 98 I can place passwords on shared drives. I can't find that
> option in XP home. Am I missing something or is Home lacking in
> security features?
> David.
Actually, it's Win98 that has virtually no real security
capabilities.
Like Win2K, WinXP's file security paradigm doesn't rely on, or
allow, the cumbersome method of password protection for individual
applications, files, or folders. Instead, it uses the superior method
of explicitly assigning file/folder permissions to individual users
and/or groups.
HOW TO Create and Configure User Accounts in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;279783
HOW TO Set, View, Change, or Remove File and Folder Permissions
http://support.microsoft.com/default.aspx?scid=kb;en-us;q308418
HOW TO Set, View, Change, or Remove Special Permissions for Files and
Folders
;Q308419]http://support.microsoft.com/default.aspx?scid=kb;[LN];Q308419
HOW TO Set the My Documents Folder as Private in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;298399
Of course, if you have WinXP Pro, you can encrypt the desired
files/folders.
Best Practices for Encrypting File System
http://support.microsoft.com/default.aspx?scid=kb;en-us;223316
As a work-around, you can place the file in a compressed folder,
and set a password to uncompress the folder to view/access its
contents.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having
both at once. - RAH
