Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Using Power over Ethernet to power two devices from a sing..
Forum Wireless Networking : Wireless General Discussions - Using Power over Ethernet to power two devices from a sing..
Archived from groups: alt.internet.wireless (More info?)
I need to find out if it is possible to use Power over ethernet to power two
devices from a single ethernet cable. I forsee a relatively standard POE
setup at the injector end. Then at the location of the first device needing
ethernet connection and power, put in an ethernet hub before the power is
split out. One ethernet output (with power ) from the hub goes right into
the POE splitter and then provides ethernet (w/o power) and power to the
first device. The second ethernet (with power ) from the hub goes on to the
second device and connects to a standard POE splitter to provide power and
ethernet to the second device.
Plan is to use Linksys POE devices to power two WRT54G Access Points.
1) Will a passibe two port hub handle all wires in the cable including the
ones with power?
2) Does the Linksys POE injector supply enough power to power two WRT54G
devices?
Better way to do this?
Bob Alston
Home: 918.494.4913
Lake: 231.893.8044
BobAlston9@AOL.com
http://members.cox.net/tulsaalstons/
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004
Sponsored Links
On Sat, 14 Aug 2004 20:56:44 GMT, "Bob Alston" <bobalston9
OK, you're cheap. I can understand that.
OK. Which WRT54G mutation? Only the original one run on 5V while
others require 12V.
http://www.linksysinfo.org/files/WRT54G%20Versions.htm
The Linksys WAPPOE only duz 5V so that will only work with the
original WRT54G.
I'll assume the 12V version which draws about 0.5A (measured in
haste). Therefore the real question is whether the WAPPOE will power
it. Well, the WAPPOE box only does 5V and not 12V power, so that
won't work. So, your options are to either find a 12V PoE system,
use an older pair of WRT54G, or build your own.
This might be worth reading:
http://www.keithl.com/Linksyspower.html
I've built a few PoE system. I'll leave out the details but basically
it's a DC-to-DC power converter, with a 24V or 48VDC input (to keep
CAT5 DC resistance losses to a minimum), and a 5V or 12V DC output. I
have one built that's running 3ea WAP11 access points on top of a
tower. I prefer Astrodyne DC-to-DC converters as some are shielded
(for low EMI/RFI) and are reasonably priced.
For running two WRT54G 12V boxes, you need at least 12V 1A output plus
whatever the hub burns. Hopefully, you can find a 12VDC powered hub.
Methinks a 20watt unit will suffice. See:
http://www.astrodyne.com/astro/pro [...] 6&watts=22
http://www.astrodyne.com/pdf/ASD20.pdf
Digging through the pile, methinks an ASD20-48S12 ($36) will work.
>ones with power?
What's a "passibe two port hub"? For that matter, where are you gonna
find a 2 port hub (with the proper bypass wiring)? I usually buy some
random hub (in this case, must be 12VDC powered), and add my own power
bypass wiring.
>devices?
Nope. WAPPOE does 5V. Most WRT54G run on 12V.
Of course. See above on DC-to-DC converters. Don't forget the fuse
or current limiter. Input source can be unregulated (i.e. solar
powered). Learn by Destroying works, but can be expensive.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
Reply to Anonymous
On Sun, 15 Aug 2004 10:17:44 -0700, Jeff Liebermann
Have you tried decaff? ;-)
Reply to Anonymous
Never touch the stuff. Need the kick.
Bob Alston
Reply to Anonymous
>>others require 12V.
>>original WRT54G.
Humm..... I am pretty sure my WRT54G is a version 2 - as I recall looking on
the bottom of the unit a while back. So that makes it 12 volt. But I
recently installed WAPPOE - and it still works.
Difficult to verify version 2 - cause I got to get out the extension ladder
and take it to the 2nd floor of the building.
Wonder why it is working??????
Have a message in to Linksys.
Bob Alston
Reply to Anonymous
There are 484 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
