Tom's Hardware > Forum > Games General > PC Gaming > Crysis 1.2 Patch problems
Forum Games General : PC Gaming - Crysis 1.2 Patch problems
So After a few months of waiting I finally decided last weekend to take the plunge, buy crysis, and see what my computer could do. When I installed the game, i searched for patches and sure enough found that crytek had just released 1.2. Thinking that only good things could come, i quickly patched the game and loaded it up.
Unfortunately, everything has not gone well. Every single humvee i encounter in the game seems to have no rear wheels at all. :pfff: They're there all right, if you shoot where the tires should be they pop and the rim appears, and the truck drives fine, but i can't see them. Also, during the cutscene where you find the frozen ship (the end of the demo) everyone appears to be holding huge black boxes instead of guns.
At first i thought it was a problem on my end, so i looked for newer drivers (there weren't any) and tried downclocking my GPU in case it was a heat issue. No luck. I played through the entire demo before buying crysis and never experienced any of these glitches, so i don't know what to think.
Should i uninstall any go back to 1.1 or even vanilla crysis? :ouch:
I am running:
EVGA 8800GTS 320
E4300 @ stock speeds
2 gigs of Patriot DDR2 - 800 @ 4-4-4-12
Thanks in advance, Joetheone
Sponsored Links
Quite an unusual issue you have there lol.
I'd try to reinstall the game. Don't overclock just yet...leave it at stock for now.
Try the first level with version 1.0 and if everything goes well then install the patch 1.2. Try again.
If all is well then overclock.
Also, make sure you run Crysis.exe without extension commands (as it might have change with version 1.2).
Message edited by Alex The PC Gamer on 03-11-2008 at 09:34:21 PM
------------------------------ Windows XP MCE & Vista 64-bit (dual boot)
XFX NFORCE 680I LT SLI w/ OCZ Platinum 4 Gigs Dual DDR2 @ 800MHz
Intel Core 2 Quad Q6600 @ 2.4GHz w/ ChillTec Thermo Electric CPU Cooler
MSI NX8800 GTX & X-Fi XtremeGamer Soundblaster
Reply to Alex The PC Gamer
I have seen several other threads about this exact problem (missing tires, etc. in v1.2), so I believe it is an issued with the patched version of the game, not with your hardware.
Reply to mtyermom
What a weird bug. I reset my RAM timings, speed, voltage, ect. to auto and have been playing the other levels and i noticed that in every level except "contact" the wheels are back on the trucks.... though I'm pretty sure now that the cutscene problem was from heat. After leaving my comp off for a night i booted up and went straight to that scene in crysis and it ran fine.
Reply to joetheone
Yeah I've got missing jeep wheels too, If you go really fast it suddenly spins you around too, as if its got blow outs.... This only stated to happen after I installed patch 1.2, having alrady had 1.1 installed.
I don't tend to use the jeeps much anyway, in hardest play mode you have to stop driving to shoot top mounted gun - its just too slow... not quite like the ending scenes of Rambo lol....
Reply to tentonnesofdoug
I had similar problems back when I had a 8800GTS 320M, in addition to giant triangles and other wierd graphic anomalies in Crysis. Other games were fine. It is a known problem with the Nvidia driver for that specific card and the fix is to change versions of the Nvidia driver. That may mean downgrading if you have the latest, so be sure to use Driver Cleaner Pro.
------------------------------ Intel Q9450 | Gigabyte GA-P35-DS4 | 4GB XMS2 PC6400 | Corsair HX520 | EVGA 8800GTS 512M | X-Fi XtremeGamer | ST3500320AS | WD5000AKKS | 2x SATA DVDRW
Reply to jtstepan
Crytek really screw this patch up and tarnished their name a bit, this is unacceptable!! :fou:
Message edited by systemlord on 03-14-2008 at 02:53:12 AM
------------------------------ Intel C2D E6600 @ 3.2GHz * Asus P5E * 2x1 GB Crucial Ballistix Tracers * Raptor X * EVGA Geforce 8800GTX 768MB 651MHz/1525MHz/2100MHz * X-FI Fatal1ty Pro * Enermax Infiniti 720W PSU * Creative THX5.1 * Tuniq Tower 120
Silverstone TJ09 * Windows XP
Reply to systemlord
There are 1361 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
  • 01:00 steelmartin won the Freshman badge
