All you need to know about Power Supplies
December 20, 2002 3:08:29 AM
http://firingsquad.gamers.com/guides/power/default.asp
This will give you just about everything you need to know about power supplies.
More about : power supplies
December 20, 2002 3:15:22 AM
I read this also. Very good article.
<i>It's your world kid!!!</i>
December 20, 2002 4:38:09 AM
Sure is a good read. I'll have to take it more into account in the future. I've always know enough about it to buy a quality case & PSU such as the Antec 1080AMG I'm running now. But being lucky isn't always as good as being smart!
Signature, I'm still learning & having fun doing it!!!!!!
December 20, 2002 8:46:55 AM
thanks - thats good info.
<i>It's always the one thing you never suspected.</i>
December 20, 2002 8:58:48 AM
I went back and read through PS I've purchased from newegg. Looks like Enermax is the champ.
December 20, 2002 12:33:29 PM
It's good to know.
Thanks a lot
December 20, 2002 3:12:04 PM
yea, i build with enermax all the time, even their base 300 watt is rock solid. voltages barly waiver. my 431 enermax runs my computer with 3 hard drives, 3 optical drives, bunch of cards, over volted cpu, and 5 high speed scsi drives. i can power down the scsi drives and power them back up and the enermax doesnt even blink.
my computer is so fast, it completes an endless loop in less than 4 seconds!
December 20, 2002 4:38:02 PM
Enermax is awesome! I have an EG465P-VE (435 Watts) and it doesn't even blink no matter what I throw at it.
My system and CPU temps dropped when I upgraded to this PSU from a 350W Antec.
"There's no such thing as gravity, the Earth just sucks."
December 20, 2002 4:40:06 PM
they dont make a 435 watt psu. and i find it very hard to believe that your cpu temp went down just by replacing the psu. maybe it could because of the better fan design on them was giving you better air flow.
December 20, 2002 4:56:49 PM
Yes, it's 431W, it was a typo.
Why are you questioning the fact that my temps dropped? Enermax PSU's have great airflow and cooling fans, which is one reason they're so good. You yourself mentioned this fact, so why would you question it?
December 20, 2002 4:58:46 PM
if the only thing you changed was the psu, the only thing that could have affected the cpu temp is air flow. the fans on those psus dont run fast at all. if you saw any difference your case must have been near stagnant.
December 20, 2002 5:12:25 PM
My previous PSU had a single fan on the back of it. The Enermax has a fan on the back AND on the underside. My airflow was not stagnant before, it is just somewhat better now. My temps only went down by a couple of degrees, nothing major. But that's still a nice benefit of the Enermax, in addition to great power.
Why do you care, anyway? Do you just cruise these boards loking for things you can question?
December 20, 2002 5:13:35 PM
its called idle conversation, lighten up.
December 20, 2002 5:17:00 PM
OK, your "tone" just seemed a little accusatory. I couldn't figure out why.
Take it easy.
Peace.
