Yes No
Ads
Tom's Hardware > Forum > Windows 95/98/ME > General Discussion > problems with EMM386.exe!!!
Forum Windows 95/98/ME : General Discussion problems with EMM386.exe!!!
I just built a new Duron system and it has been working great. No problems along the road until now. Suddenly, when windows loads, I get blue-screen-of-death just as my desktop shows up. By using the step-by-step option in the windows boot menu, I think i narrowed it down to the emm386.exe file as causing the problems because when i load everything else but that file, the computer works fine. Any advice on how to fix it? I am using the latest Via 4-in-1 drivers on an Abit KT7A. Thanks very much in advance.
Reply to psuman
Sounds like a memory conflict, with emm386 taking some prime real-estate. You can chuck emm386, put in something like an E=C000-C777 line, or take out the RAM flag on the config line.
Reply to ejsmith2
- 0 +
you mean just erase the file and insert that E=.... line into config.sys?
Reply to psuman
- 0 +
Did you just drop the old hard drive and OS onto a new board? Post win95 the OS does not need config.sys at all. I was shocked to read you still had emm386.exe on your machine.
Instead of deleting the line in the config.sys just REM it out:
REM loadhigh=emm386.exe C700-D0000 (Example)
See if that works.
BTW What OS are you using?
What did we do before we had computers?
Reply to breed33
There are 1735 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need insight on my pc with windows 98 OS
By wombat_tg, 6 days ago:
You will need a dial-up account with an ISP in order to make use to that modem. (You're...
Best offers
Top experts
