Tom's Hardware > Forum > Systems > HP > Problem powering up 735
Archived from groups: comp.sys.hp.hardware (More info?)
Hi,
After a power outage, we have bee unable to re-start our venerable 735.
When we press the power button, some lights come up for a short time and
then come off (it seems that the lights come up while the button is being
pushed). Once you release the switch, nothing happens.
Has anyone experienced this problem? Does anyone have a suggestion? Does
HP still service these machines?
Thanks,
Gabriel
Sponsored Links
I forgot o mention this is an HP 9000 Model 735 Unix workstation. HP has so
many products that there may be other 735's out there.
Thanks,
Gabriel
Reply to Anonymous
G.R. Toro wrote:
> Hi,
Most likely the same or similar problem as my 712 had: it was off long enouth to
let the harddisk cool-down. With that, the grease in the harddisks fastens the
disks and prevents further spin of the platters.
If you have a relyable backup, prepare for a restore on a new disk: buy one and
restore.
If you ahve no relyable backup, have the disk recovered. This will cost (lots)
of money. Buy a new one and move over to use that instead.
If you have the guts (and prepare for error) open the disk and try to twist the
disks manually. You will need proper tools and a fairly clean area. If you just
dusted or hoovered the area, wait a couple of hours to let the dust stabilize in
the air. Be verry carefull not to scratch the platters with the heads. Be sure
to only gently twist the disks, the less you twist them the better, however, be
sure they can twist easy. It is as if breaking a seal.
After closing and restoring the disk, best to copy the contents to an other disk
as fast as possible, poreferably by `dd`ing the entire disk to a new disk. THen
try to use the new disk.
FWIW, I'm living on the edge now, I still use the once-frozen disk... on my test
system.
CBee
Reply to Anonymous
CBee <I.Dont@want.your.spam> writes:
> enouth to let the harddisk cool-down. With that, the grease in the harddisks
> fastens the disks and prevents further spin of the platters.
But if you cook the drive over low heat in an oven (or in a sauna, if
you're up here :) it should spin again!
Atro Tossavainen (Mr.) / The Institute of Biotechnology at
Systems Analyst, Techno-Amish & / the University of Helsinki, Finland,
+358-9-19158939 UNIX Dinosaur / employs me, but my opinions are my own.
< URL : http : / / www . helsinki . fi / %7E atossava / > NO FILE ATTACHMENTS
Reply to Anonymous
An old drive with sticking platters can often be coaxed into action by plugging
and unplugging the power connector on the drive itself. This often causes
enough of a controlled voltage surge to get the platters to move... Ben Myers
On 24 Jun 2004 09:56:27 +0300, Atro Tossavainen
Reply to Anonymous
CBee <I.Dont@want.your.spam> wrote:
>> 735. When we press the power button, some lights come up for a
>> short time and then come off (it seems that the lights come up
>> while the button is being pushed). Once you release the switch,
>> nothing happens.
> long enouth to let the harddisk cool-down. With that, the grease in
> the harddisks fastens the disks and prevents further spin of the
> platters.
I would have thought that if it were the disc seized-up, the system
would at least get through power-on self test and the like and then
would report an inability to boot from the primary boot path.
I don't recall what the symptoms were of a failed button battery on
the system board, but that might be worth a look. Also making sure
that all the boards are properly seated wouldn't hurt.
rick jones
Wisdom Teeth are impacted, people are affected by the effects of events.
these opinions are mine, all mine; HP might not want them anyway... :)
feel free to post, OR email to raj in cup.hp.com but NOT BOTH...
Reply to Anonymous
There are 633 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
