I'm not quite sure if this problem has to do with the motherboard, but I didn't know where else to post it...
Let me first start by listing my hardware config:
-Soyo P4X400 Dragon Lite Motherboard
-P4 "Northwood" 2.4Ghz socket 478
-512MB Kingston PC2100 RAM
-Western Digital WD800JB HD
-Leadtek GeForce4 Ti4200 Winfast A280 LE
-LinkSys Network Everywhere Fast Ethernet Adapter (NC100 v2)
-ASUS CD-S520/A CD-ROM drive
-450watt Chieftec Power Supply
-OS: Windows 2000 Professional
Ok, well I just built this system a few days ago. For some reason, the system reboots itself, occasionally, at random. I updated the BIOS to it's most recent version, and to my knowledge, all the drivers are up-to-date.
**NOTE** I have not seen it reboot while the system is idle. It tends to reboot after performing an "action". This action could be anything from double-clicking an icon on my desktop, to logging into Windows 2000 Pro.
I don't think it is a heat issue. I have 4 case fans (2 intake, 2 exhaust), CPU fan, video card fan, and Power Supply fan. With my hardware monitoring software, the "CHATEMP" (which I believe is the motherboard), is usually at 28 degrees Celsius, and the CPU is usually at 41 degrees Celsius.
My hardware monitoring software also keeps track of the voltages to the main components, and the voltages are all in the "green" zone. The "+12V" tends to fluctuate between 11.78V and ll.84V (not sure if this is a problem).
Earlier tonight, I booted up my computer and got a blue screen stop error. The message read as follows:
"A device driver has corrupted the system memory pool..."
It also said that I may be able to "run driver verification" to pinpoint the problem...not sure how to do this. Well, anyway...I reboot after the blue screen and it seems to boot up normally, and I have been on my comp since (about an hour and a half) without any reboots.
If anyone has had similar experiences, or has any ideas as to what the problem might be and how to fix it, I would really appreciate your input.
In Windows 2000, the automatic reboot is the default for when you get a BSOD (Blue Screen of Death). Lots of things can cause it but based on your description, I expect you may have a software/driver conflict of some sort. To avoid the reboots, go into your system properties, advanced tab, startup and recovery and uncheck the "automatically reboot" box, then at least when it fails, it'll give you some sort of error message that may point you in the direction of the problem.
You are not overclocking, right? I'm not real familiar with the Via P4 chipset, so it's hard for me to make any specific recommendations. See if you can get any error messages when the system fails and go from there.
Oh, and another thought... I've had some bad experiences with that Network Everywhere NIC you have. Basically it has some power polling problems that stops the boot process on some machines. I realize this isn't really your exact problem, but not knowing how that PX4 chipset would react to the card, perhaps it is causing problems. You might try taking it out and see if that solves your problem.
download it here at <A HREF="http://hcidesign.com/memtest/MemTest.zip" target="_new">http://hcidesign.com/memtest/MemTest.zip</A> and follow the instuctions.
<font color=red><b>If Micro$oft is sooooo smart, how come SP1 works on my Windows XP Corporate Edition huh?</b></font color=red>
I followed your advice and disabled the "automatically reboot" option. The next time the comp rebooted itself, I got a blue screen stop error that read:
That stop code is caused by a memory violation. What you need to do now is go to the Microsoft Knowledge base and put that stop code in and read the articles to see if any apply to your computer. I looked at a few and it seems that your issue might be due to some hardware combinations that Microsoft has fixed in their service packs. Have you installed any of their Win2k service packs?
I would set all your bios settings to default. I would also try raising your memory voltage to 2.6 or 2.7, and see if this helps stability. Check your hardware monitor and see what the default cpu vcore is. If it's under 1.5 volts, I would raise that setting a little to just above 1.5. Some boards come undervolted, while my asus is slightly overvolted at default.
According to my hardware monitor, the CPU Vcore voltage is 1.44V, while the DDR seems to be hopping back and forth between 2.48V and 2.50V. Also, the +12V reading fluctuates between 11.78V and 11.84V. Is it normal for some of the readings to fluctuate slightly?
Do you really think the voltages would have anything to do with that stop error?
I had a problem with frequent shutdowns or reboots once after building...try checking bezel connections (I once made the mistake of putting p+ & p- leds on the pins for sleep leds. Currently, I too am having a reboot problem...but just in demanding games ( might check this again for my self...though in my case I don't think this is it...am running stable when not in heavy game).......good luck
Hmm...what are bezel connections? Are you talking about the LED connectors from the case to the motherboard? I connected all the black wires to the negative (ground) on the motherboard.
Beginning dump of physical memory
Physical memory dump complete. Contact your system administrator or technical support group.
It really doesn't make sense that these stop errors are being caused by a faulty power supply, it seems like more of a memory issue. Perhaps my RAM is bad.
I "assumed" that everything was fine, in terms of IRQs, since my device manager wasn't reporting any conflicts.
However, upon looking at all the devices manually, I noticed that my video card (winfast A280 LE) and onboard sound (CMI8738/C3DX PCI Audio Device) are both using IRQ 16! Anyone know how to change this, because this is most likely the root of the problem, or at least one of the problems.
Also, I noticed that all 3 "VIA USB Universal Host Controllers" are using IRQ 21, but I'm guessing they are supposed to be using the same IRQ.
I am having a similar problem - I think its because my PSU is only 120 watts!
See below my problem!I recently installed new motherboard XFX P4XE-MVB along with Celeron 2.0 and 512 DDR PC-2100.
I finally got it running for a couple of days after installing new hard drive but now I am having problems.
The computer starts rebooting itself while running programs. I was running TmpGen encoding an .avi file when this happens. Also, when I am running Sonic MyDVD!
***Address B65B46A9 base at B65B4000, DateStamp 38437edd - nwlnkipx.sys
Do you think all of these stop errors are being generated by the shared IRQ between my video and sound? Also, I still don't know how to change the IRQs.
I am not familiar with those errors? My system keeps rebooting similar to yours but with no error messages.
I also purchased 2 PNY PC2100 DDR 256 sticks and noticed the label on one said 266 a and the other said 266 b? I dont know if that would cause a problem with my system?
Well, I just ordered a new case with 350W PSU from Tiger Direct. I hope this solves the problem!
Refer to motherboard manual...and use a good magnifying glass (preferably one with a light attached)...the writing on the mobo connector pins is very tiny (but this writing along with manual will guide you)...match marked pins with wire leds from front of case (bezel)...I find this one of the most tedious jobs (next to loading drivers) when building a system. If they are wrong...yes... it can cause shutdown problems...like I said earlier I one time put the p+ & p- leds on the sleep + & - pins (the sleep pins were supposed to be left with no connector). It kept shutting down my system...truthfully I can't remember if if was a total reboot.....and it's not guaranteed that this is your problem...but it's worth a look.........gl
P.S. When I put the p+ & p- leds on their proper pins (after closer inspection) my problem was solved.
