Archived from groups: comp.sys.hp.hardware (More info?)
Anybody know the maximum weight that can be placed safely on a
712/60? I imagine that a mid-90s Trinitron (IBM POWERdisplay 20) would
be OK, yes?
David Evans dfevans@bbcr.uwaterloo.ca
Ph.D. Candidate, Computer/Synth Junkie http://bbcr.uwaterloo.ca/~dfevans/ University of Waterloo "Default is the value selected by the composer
Ontario, Canada overridden by your command." - Roland TR-707 Manual
David, I have a 712/80 at home with a mid-90s 19" HP monitor sitting on
top of it. No problems.
Phil
"David Evans" <dfevans@bcr10.uwaterloo.ca> wrote in message
news:cb2i7u$9ra$1@rumours.uwaterloo.ca...
> be OK, yes?
> David Evans
http://bbcr.uwaterloo.ca/~dfevans/ > University of Waterloo "Default is the value selected by the
composer
Manual
In article <40d6f3b4$0$203$75868355@news.frii.net>,
I've heard similar things from others. Thanks a lot.
> be OK, yes?
Fwiw, I had a 19"-trinitron-hp monitor that came with it. It stood there for a
couple of years.
If you open the case, you will see it is filled with hard-foam and such that
will carry the load.
btw: the 712 came with a side-stand so it can be placed as a desk-side machine:
no-one will notice it is there.
