Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > system state backup vs. system restore point
Forum Windows XP : Windows XP General Discussion - system state backup vs. system restore point
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
(XP Home SP2)
Hi - I know that the 'system state' option in NTbackup is limited to
system files, and system restore tries to cover files all over the
computer. But I find that using system restore can have some
non-intuitive behavior (nothing serious, but sometimes it doesn't quite
get everything the way I would expect in outlying folders), and I'm
wondering. If all I'm going to do is install a piece of software, and
I'm concerned that I won't like it and immediately do an uninstall, is
it safer to use system state backup and restore (knowing that this won't
effect anything out of the system areas, which is an advantage in this
case), rather than to risk the possibly more substantial behavior of a
system restore operation for something this minor. System restore
strikes me as something to use when you have to go back days, rather
than minutes, and you're willing to have to do some cleanup to get
everything right again.
thanks!
/j
Sponsored Links
System Restore is what I would use, but it seems you do not want to,
Jeff. ASR is a much larger operation
How to Set up and Use Automated System Recovery in Windows XP
http://www.microsoft.com/technet/p [...] n/asr.mspx
" The wizard backs up the system state, system services, and all
disks associated with the operating system components. It also
creates a file containing information about the backup, the disk
configurations (including basic and dynamic volumes) and how to
accomplish a restore. "
Frequently Asked Questions Regarding System Restore in Windows XP
http://www.microsoft.com/technet/c [...] srwxp.mspx
" How is System Restore different from Backup?
Answer: Unlike System Restore which monitors only a core set of
specified system and application file types (e.g. .exe, .dll etc),
the Backup Utility usually backs up all files including users
personal data files, ensuring a safe copy stored either on the local
disk or to another medium. System Restore does not monitor changes
to or recover users' personal data files such as documents,
drawings, e-mail, and so forth. While system data contained in
System Restore's restore points are available to restore to for only
a limited period of time (by default restore points older than 90
days are deleted), backups taken by the Backup Utility can be
recovered anytime.
What files are monitored by System Restore?
Answer: System Restore monitors only a core set of specified system
and application file types (e.g. .exe, .dll etc), archiving the
states of these files before system changes are made. System Restore
does not monitor any user/personal data files. To view the included
files specified in System Restore, see Monitored File Extensions in
the System Restore section of the Platform SDK available from
http://msdn.microsoft.com/library/ [...] nsions.asp
MowGreen [MVP]
*-343-* FDNY
Never Forgotten
Jeff W wrote:
> (XP Home SP2)
> thanks!
> /j
Reply to Anonymous
not a question of want - i think the hierarchy of severeness is
least:
NTBackup of system state
system restore
ASR
most
I have XP home so i'm notsure I can use ASR. I'm just wondering if
NTbackup with system state is a LESS disruptive, yet effective approach
for a small rollback
/j
Reply to Anonymous
An Error Message Is Displayed When You Attempt to Use the Automated
System Recovery Wizard
http://support.microsoft.com/kb/302700/EN-US/
" This behavior can occur because ASR is not supported in Windows XP
Home Edition. However, Windows XP Home Edition users can access the
ASR Wizard if they install the Ntbackup program from the Valueadd
folder on the Windows XP Home Edition CD-ROM. "
As to why one would choose Restore over Backup :
Files That Are Automatically Skipped by the Backup Program
(NTBackup.exe) During the Backup and Restore Processes
http://support.microsoft.com/?id=104169
The choice is yours, Jeff.
MowGreen [MVP]
*-343-* FDNY
Never Forgotten
> least:
> system restore
> ASR
> most
> /j
Reply to Anonymous
Did you read the article you gave a link to? It says
"The information in this article applies only if Backup cannot do a
volume shadow copy backup or if you select the *Disable volume shadow
copy* option in the *Advanced* dialog box for an individual backup job."
So if I don't set the "skip files" option, it doesn't.
Which means my question remains - hopefully someone has a good answer
/j
>MowGreen [MVP]
> *-343-* FDNY
>Never Forgotten
>> least:
>> system restore
>> ASR
>> most
>> /j
Reply to Anonymous
Jeff W wrote:
> (XP Home SP2)
> quite get everything the way I would expect in outlying folders), and
> I'm wondering. If all I'm going to do is install a piece of
> software, and I'm concerned that I won't like it and immediately do
> an uninstall, is it safer to use system state backup and restore
> (knowing that this won't effect anything out of the system areas,
> which is an advantage in this case), rather than to risk the possibly
> more substantial behavior of a system restore operation for something
> this minor. System restore strikes me as something to use when you
> have to go back days, rather than minutes, and you're willing to have
> to do some cleanup to get everything right again.
> thanks!
> /j
It seems to me that what you need is Total Uninstall
http://www.geocities.com/ggmartau/tu.html
HTH,
OldKenGoat
To reply JUNK the NOJUNK!
Reply to Anonymous
There are 722 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
