Recycle Bin Problem.
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I use winxp/sp2. When I delete email files from Outlook Express they do not
show in Recycle Bin. Same is true for other files. Recycle Bin Properties
does NOT have the "Do not move files to the Recycle Bin..." box checked. I
use "Freedom" anti-virus software from my ISP (Adelphia).
How do I persuade Recycle Bin to retain my deleted files until I want to
remove them permanently?
Peter.
9 answers Last reply
More about recycle problem
  1. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Hi,
    First, deleted email from Outlook Express does not use the Recycle Bin, it
    goes to the deleted items folder in Outlook Express. Once removed from
    there, then it is permanently gone.
    Why the Recycle Bin is not receiving other deleted files is another issue.
    Possibly a stuck <shift> key, as shift+delete will bypass the Recycle Bin.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Associate Expert - WindowsXP Expert Zone
    www.microsoft.com/windowsxp/expertzone
    Windows help - www.rickrogers.org
    "PVR" <peterv666@adelphia.net> wrote in message
    news:ucGdnRCTmpL3gOXcRVn-gg@adelphia.com...
    > Peter.
  2. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Oops, now I feel quite dumb re: deleted emails. However the other problem
    still remains and the <shift> key works OK with other functions.
    Thanks for your help.
    Peter.
    "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
    news:Oxg9GB9tEHA.3972@TK2MSFTNGP15.phx.gbl...
    > Hi,
    > Best of Luck,
    >>not show in Recycle Bin. Same is true for other files. Recycle Bin
    >>Properties does NOT have the "Do not move files to the Recycle Bin..." box
    >>checked. I use "Freedom" anti-virus software from my ISP (Adelphia).
    >> Peter.
  3. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    You can ty this >>
    http://www.kellys-korner-xp.com/xp_tweaks.htm
    Read instructions at the top
    64. Right hand side
    Replace/Repair the Recycle Bin in Windows XP
    Hope this helps. Let us know.
    Wes
    In news:5I-dnTmhdZCycOXcRVn-vg@adelphia.com,
    PVR <peterv666@adelphia.net> hunted and pecked:
    > problem still remains and the <shift> key works OK with other
    > functions.
    > Peter.
    >> Hi,
    >> Bin, it goes to the deleted items folder in Outlook Express. Once
    >> removed from there, then it is permanently gone.
    >> issue. Possibly a stuck <shift> key, as shift+delete will bypass the
    >> Recycle Bin.
    >> Best of Luck,
    >>> they do not show in Recycle Bin. Same is true for other files.
    >>> Recycle Bin Properties does NOT have the "Do not move files to the
    >>> Recycle Bin..." box checked. I use "Freedom" anti-virus software
    >>> want to remove them permanently?
    >>> Peter.
  4. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Hi,
    No reason to feel dumb. You didn't know so you asked. Let us know if Kelly's
    fix helps.
    Best of Luck,
    news:5I-dnTmhdZCycOXcRVn-vg@adelphia.com...
    > Peter.
    >> Hi,
    >> it goes to the deleted items folder in Outlook Express. Once removed from
    >> Recycle Bin.
    >> Best of Luck,
    >>>box checked. I use "Freedom" anti-virus software from my ISP (Adelphia).
    >>> Peter.
  5. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Short answer is "Yes, it worked, although I have only deleted one file so
    far. Many thanks.
    The long answer is that in order to Backup the registry I had to install
    Backup from the WinXP disc which meant finding that disc, ad nauseum. But it
    does work. Whoopee!
    Peter.
    "Wesley Vogel" <123WVogel955@comcast.net> wrote in message
    news:ebSEFSEuEHA.3156@TK2MSFTNGP12.phx.gbl...
    > You can ty this >>
    > 64. Right hand side
    > Wes
    >> functions.
    >> Peter.
    >>> Hi,
    >>> Recycle Bin.
    >>> Best of Luck,
    >>>> Peter.
  6. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    I've been trying to figure why my Recycle Bin went bad. I had Norton System
    Works installed on this computer. This included Norton's "Protected Recycle
    Bin." I decided to uninstall System Works in favor of something else. Is it
    possible this uninstallation caused the standard Recycle Bin to go bad?
    Peter.
    news:OA$dxDJuEHA.220@TK2MSFTNGP15.phx.gbl...
    > Hi,
    > Kelly's fix helps.
    > Best of Luck,
    >> Peter.
    >>> Hi,
    >>> Recycle Bin.
    >>> Best of Luck,
    >>>> Peter.
  7. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    On Fri, 22 Oct 2004 08:36:30 -0600, "Wesley Vogel"
    <123WVogel955@comcast.net> wrote:
    >You can ty this >>
    >64. Right hand side
    Am I supposed to just add this file to my registry when prompted? Is
    it safe?
  8. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Hi Teresa,
    Yes you are and yes it is. Kelly has been developing and distributing these
    for years. She tests everything on her own systems, and would never put up
    anything malicious.
    Best of Luck,
    <teresa3480@cs.com> wrote in message
    news:9alqq05nkr3fnhvqodpbrh9iu65q3frbuf@4ax.com...
    >>You can ty this >>
    >>64. Right hand side
    > it safe?
  9. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    On Wed, 1 Dec 2004 06:08:06 -0500, "Rick \"Nutcase\" Rogers"
    <rick@mvps.org> wrote:
    >Hi Teresa,
    >anything malicious.
    Thank you, Rick but the fix didn't do anything for me. Here's how I
    did it finally!
    My computer>C drive>folder options to show all system and hidden
    files>select and delete Recycler(with the icon)>restart
Internet Service Providers Windows XP
