Hello! First, a bit about myself and my situation: I am an Alberta (that's in Canada) University student who normally doesn't do much coding. however, unfortunately my course load this semester has taken an unexpected turn, and I need to make some changes to my computer:
I am running a computer that is no longer what I need, and it has to go as soon as I get my new rig up, running, and online.
This new rig was originally planned for about easter at the earliest, so I have been casually educating myself about hardware so my next computer could be scratch built (something I have wanted to do for a while now). but now, I need to move the timetable ahead from about 4 months away to now. Right now, unfortunately. I have to have my new computer up and running ASAP, inside of two weeks ideally. Tomorrow I go monitor and case shopping. From there I start mail ordering from the states all the components that aren't too heavy to practically ship across international borders.
So, where do you come in? I don't know near as much as I would like about what I am doing, but having to make the best of it, I am throwing some components together and hoping it all works out and I can learn more as I go along. Here is my proposed system, please let me know about any concerns with it or anything I should do differently.
Motherboard: asus a7n8x deluxe motherboard.
Ram: 2 sticks 256 mb corsair ram: I am thinking pc2700. Is this appropriate? (I am told that slots 1 and 3 are the ones to put them in... correct?)
Processor: Athlon xp 2100+: processors is something I don't know much about at ALL. I mostly looked at motherboards, storage, audio, and video when I was doing research. Any advice on this would be welcome.
Cooler: Thermalright slk-800. I read in several places that it is heavy enough to throw through a cinder block wall, and that it works very well.
Hercules 9700 pro radeon. (good bundled software, not likely to need upgrading in the near future.)
twin 60 gig 7200 rpm hard drives (ata 100). Undecided as of yet on exact model numbers and brand names.
Floppy drive: yes, I will have one. As I understand, it makes absolutely no difference what kind I have.
Undecided on cd drive: I have an external usb cd-rw unit I will likely use until I can make this decision at a later date: I don't need to be playing games on this thing in the near future, it just has to be running appropriate mathematics and coding software by the tail end of the month. I plan on using a dvd/ cdrw combo (edit: just realized that dvt/ cdrw combo could be interpereted as one drive that did all functions. In fact, mean "one dvd drive, and one cdrw drive."), like many others, but that is something I think can wait until I can better decide what I want/need.
Originally, I had hoped to find a lian li pc60 case in my home town, and a well priced 19" viewsonic p95f monitor, but with the new time frame, I will likely settle for the easier to find antec cases and I don't know what I will find for monitors. I am holding off on power supplies till I see if I end up with one supplied with the case. Approximately how much wattage would I need to get this system up and running (assuming I add a 19 inch crt monitor, 2 optical drives, all the standard usb peripherals, and having some room for bells and whistles and dabbling in overclocking)?
Needless to say, I have the appropriate mice, keyboards, etc, kicking around, and I plan to use onboard sound until I can decide a little more firmly on what is the "right" sound card, and I will be holding off on speakers for the same reason. Onboard network, I believe, is on the card, so I should be all right there, or so I hope.
So, sorry about the long and rather disjointed post, but unfortunately I am in way more of a hurry than I had anticipated. What I would like to know, is will there be anything I will suddenly realize I don't have when I try to put this thing together (other than the obvious thermal compound, fans, and possibly psu?)? Is there anything I will regret buying later?
What do I use my computer for? Writing various office documents, matlab, maple, some basic coding in c++, and this new machine is going to need to boot unix (something I know almost nothing about, but that is not a pressing concern), watching dvd movies, as a home theatre, and a little gaming. Obviously, everything but the "work" can wait. Processor recommendations are especially welcome: I am not even sure as to what is compatible with the motherboard: can I put any socket A/462 processor into the motherboard? If not, what can I put into the motherboard? I went rather low end on processors to put some cash into a decent 3d card, because there weren't a lot of really attractive other options, from what I could see on the market right now (low end radeons up here are not fantastically cheaper than high end radeons, and from what I can tell, geforces are NOT the way to go at present.) will the slow processor hurt me a lot? Would it be worth my while on this rather budget system to go a little higher (though realistically, a 2700 processor is NOT going to be in the works for me).
Thanks for any assistance you can provide about what will/won't work with this motherboard, what is a good idea, what is a bad idea, and what I will need to get this thing up and running. Just wish I hadn't found myself in this sort of situation.
<P ID="edit"><FONT SIZE=-1><EM>Edited by timmie on 01/11/03 01:51 AM.</EM></FONT></P>
