Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Would someone kindly let me know to which group I should my question on
virtual memory. Thanks in advance Pat Miller
Sponsored Links
Hi Pat
For problems with VM, please have a look at the following article by Alex
Nichol:
"Virtual Memory in Windows XP"
http://aumha.org/win5/a/xpvm.php
Will Denny
MS-MVP - Windows Shell/User
Please reply to the News Groups
"Pat Miller" <tuaz007@earthlink.net> wrote in message
news:OO9zGaTvEHA.2804@TK2MSFTNGP14.phx.gbl...
Reply to Anonymous
Hi Pat,
This one is fine, what is your question?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
Reply to Anonymous
Hi Rick,
Using PC with XP home edition Ver.2002 w/Service Pack 2
Pentium 4CPU 1.80GHz, 1.79 GHz 256 MB of RAM
HP printer 5650
When I attempt to print a greeting card I get the following message:
Virtual Memory Minimum is too low.
Your system is low on virtual memory, windows is managing the size of your
virtual memory paging file. During this process, memory requests for some
application may be denied. Three can happen at this point. a) the system
freezes b) anywhere from 20 to 45 minutes the printer will print a card
correctly c) the print is solid black lines.
My Question is - How do I increase the Virtual memory? Do I need to get
more MB's of memory? Should I complain to the Print Shop maker?
Regards,
Pat Miller
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
news:%23TK6$dUvEHA.3872@TK2MSFTNGP11.phx.gbl...
: Hi Pat,
: This one is fine, what is your question?
: Best of Luck,
: Rick Rogers, aka "Nutcase" - Microsoft MVP
: http://mvp.support.microsoft.com/
: Associate Expert - WindowsXP Expert Zone
: www.microsoft.com/windowsxp/expertzone
: Windows help - www.rickrogers.org
: "Pat Miller" <tuaz007@earthlink.net> wrote in message
: news:OO9zGaTvEHA.2804@TK2MSFTNGP14.phx.gbl...
: > Would someone kindly let me know to which group I should my question on
: > virtual memory. Thanks in advance Pat Miller
Reply to Anonymous
see http://aumha.org/win5/a/xpvm.htm
Virtual memory is space reserved on the hard drive for when
the RAM isn't enough to handle the task. It is slower
because it is mechanical read/writes rather than electronic
in/out of RAM.
But yes, you should buy another 256 or even 512 MB.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
news:%23mJ$C2VvEHA.4072@TK2MSFTNGP15.phx.gbl...
| Hi Rick,
| HP printer 5650
following message:
the size of your
requests for some
print a card
I need to get
maker?
| Regards,
| Pat Miller
| : Hi Pat,
| : Best of Luck,
Reply to Anonymous
Hi Will,
I took a look at the recommended information - it is far beyond my
comprehension, but thanks for the try.
Pat Miller
"Will Denny" <willdenny@mvps.org> wrote in message
news:eRSsWdTvEHA.3840@TK2MSFTNGP12.phx.gbl...
: Hi Pat
: For problems with VM, please have a look at the following article by Alex
: Nichol:
: "Virtual Memory in Windows XP"
: http://aumha.org/win5/a/xpvm.php
: Will Denny
: MS-MVP - Windows Shell/User
: Please reply to the News Groups
Reply to Anonymous
Hi Pat,
Has the system always down this? Can you also give some specifications on
the motherboard, or provide the manufacturer and model number? Belarc
Advisor can help you gather this information if you are unsure, see
www.belarc.com
Best of Luck,
> Hi Rick,
> HP printer 5650
> system
> Regards,
> Pat Miller
> : Hi Pat,
> : Best of Luck,
> on
Reply to Anonymous
Also, what application software are you using to print the
greeting card? Is it something from HP that you got with
the printer or paper? Is it a "plug-in" to some other
program, such as WORKS or WORD, or is it stand-alone?
news:%23$ub0pZvEHA.3872@TK2MSFTNGP11.phx.gbl...
| Hi Pat,
specifications on
number? Belarc
unsure, see
| www.belarc.com
| Best of Luck,
| > Hi Rick,
| > HP printer 5650
following message:
requests for some
point. a) the
| > system
will print a card
Do I need to get
Shop maker?
| > Regards,
| > Pat Miller
| > : Hi Pat,
| > : Best of Luck,
should my question
| > on
Reply to Anonymous
Hi Rick,
No not always. Last year for Christmas I got a new Printer HP 5650 and
Software from Broderbund The Print Shop 20 - I have been unable to print
cards because of the memory problem - so finally decided to try to do
something about it. :) Perhaps getting more memory is the answer. If so,
where do I get it and is it easy to install?
I have a Dell Dimensions 8300 - went thru the systems list and could not
spot the motherboard.
Pat Miller
: Hi Pat,
: Has the system always down this? Can you also give some specifications on
: the motherboard, or provide the manufacturer and model number? Blear
: Advisor can help you gather this information if you are unsure, see
: www.belarc.com
: Best of Luck,
: news:%23mJ$C2VvEHA.4072@TK2MSFTNGP15.phx.gbl...
: > Hi Rick,
: > Using PC with XP home edition Ver.2002 w/Service Pack 2
: > Pentium 4CPU 1.80GHz, 1.79 GHz 256 MB of RAM
: > HP printer 5650
: > When I attempt to print a greeting card I get the following message:
: > Virtual Memory Minimum is too low.
: > Your system is low on virtual memory, windows is managing the size of
your
: > virtual memory paging file. During this process, memory requests for
some
: > application may be denied. Three can happen at this point. a) the
: > system
: > freezes b) anywhere from 20 to 45 minutes the printer will print a card
: > correctly c) the print is solid black lines.
: > My Question is - How do I increase the Virtual memory? Do I need to get
: > more MB's of memory? Should I complain to the Print Shop maker?
: > Regards,
: > Pat Miller
: > "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
: > news:%23TK6$dUvEHA.3872@TK2MSFTNGP11.phx.gbl...
: > : Hi Pat,
: > : This one is fine, what is your question?
: > : Best of Luck,
: > : Rick Rogers, aka "Nutcase" - Microsoft MVP
: > : http://mvp.support.microsoft.com/
: > : Associate Expert - WindowsXP Expert Zone
: > : www.microsoft.com/windowsxp/expertzone
: > : Windows help - www.rickrogers.org
: > : "Pat Miller" <tuaz007@earthlink.net> wrote in message
: > : news:OO9zGaTvEHA.2804@TK2MSFTNGP14.phx.gbl...
: > : > Would someone kindly let me know to which group I should my question
: > on
: > : > virtual memory. Thanks in advance Pat Miller
Reply to Anonymous
If, as you say, your virtual memory is being managed by
Windows, when you see the message, Windows is increasing the
amount of space on the hard drive assigned (set aside) for
virtual memory. It is called virtual memory because it
isn't really memory, it just acts like it is memory. Memory
is RAM, Random Access Memory, the small circuit boards with
about 8 memory chips attached. Real RAM is much faster than
virtual memory, which works at the speed of your hard drive.
HP has a nice new feature on their website www.hp.com in
that they now can scan your computer for needed driver
updates. Go to HP and click on the "software and driver"
link, enter the model number in the search field and you
will find the page that offers the downloads. You'll see a
link for "scan my computer" so just click that. I think
your problem is with the printer drivers and the Printshop
software.
Update the printer drivers and perhaps reinstall the
software.
To answer the question about installing RAM, it is easy to
do. Dell even prints directions in the manual and on-line,
showing you how to open the computer case and insert the
RAM. You can call Dell tech support and confirm the type of
RAM you need or go to www.crucial.com and use the memory
selector. You can buy RAM at all computer stores, and
stores such as Best Buy or Circuit City and office supply
stores such as Office Max or Office Depot.
Dell may have used one 256 MB RAM stick or two 128 MB
sticks, you may have only two slots to add RAM, so you want
to know what you have installed and Bel Arc will tell you
that, then decide whether you want to add more RAM and how
much you want to spend.
You might have problems with the print spooler software or
some other program using a large amount of the computer CPU
cycles, in general 256 MB of RAM functions pretty well if
you are only running a few programs, but 512-1 GB is enough
that virtual memory is not used very much and that makes the
computer faster.
news:%23xsraNbvEHA.200@TK2MSFTNGP11.phx.gbl...
| Hi Rick,
Printer HP 5650 and
unable to print
to try to do
the answer. If so,
and could not
| Pat Miller
| : Hi Pat,
specifications on
number? Blear
unsure, see
| : www.belarc.com
| : Best of Luck,
| : > Hi Rick,
| : > HP printer 5650
following message:
| your
memory requests for
| some
point. a) the
| : > system
will print a card
Do I need to get
Shop maker?
| : > Regards,
| : > Pat Miller
message
| : > : Hi Pat,
| : > : Best of Luck,
message
should my question
| : > on
Reply to Anonymous
Jim, really appreciate the good help. This is good information, all of
which I feel I can do. Again thanks a bunch.
Pat Miller
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:uVlUfabvEHA.2016@TK2MSFTNGP15.phx.gbl...
: If, as you say, your virtual memory is being managed by
: Windows, when you see the message, Windows is increasing the
: amount of space on the hard drive assigned (set aside) for
: virtual memory. It is called virtual memory because it
: isn't really memory, it just acts like it is memory. Memory
: is RAM, Random Access Memory, the small circuit boards with
: about 8 memory chips attached. Real RAM is much faster than
: virtual memory, which works at the speed of your hard drive.
: HP has a nice new feature on their website www.hp.com in
: that they now can scan your computer for needed driver
: updates. Go to HP and click on the "software and driver"
: link, enter the model number in the search field and you
: will find the page that offers the downloads. You'll see a
: link for "scan my computer" so just click that. I think
: your problem is with the printer drivers and the Printshop
: software.
: Update the printer drivers and perhaps reinstall the
: software.
: To answer the question about installing RAM, it is easy to
: do. Dell even prints directions in the manual and on-line,
: showing you how to open the computer case and insert the
: RAM. You can call Dell tech support and confirm the type of
: RAM you need or go to www.crucial.com and use the memory
: selector. You can buy RAM at all computer stores, and
: stores such as Best Buy or Circuit City and office supply
: stores such as Office Max or Office Depot.
: Dell may have used one 256 MB RAM stick or two 128 MB
: sticks, you may have only two slots to add RAM, so you want
: to know what you have installed and Bel Arc will tell you
: that, then decide whether you want to add more RAM and how
: much you want to spend.
: You might have problems with the print spooler software or
: some other program using a large amount of the computer CPU
: cycles, in general 256 MB of RAM functions pretty well if
: you are only running a few programs, but 512-1 GB is enough
: that virtual memory is not used very much and that makes the
: computer faster.
: The people think the Constitution protects their rights;
: But government sees it as an obstacle to be overcome.
: news:%23xsraNbvEHA.200@TK2MSFTNGP11.phx.gbl...
: | Hi Rick,
: | No not always. Last year for Christmas I got a new
: Printer HP 5650 and
: | Software from Broderbund The Print Shop 20 - I have been
: unable to print
: | cards because of the memory problem - so finally decided
: to try to do
: | something about it. :) Perhaps getting more memory is
: the answer. If so,
: | where do I get it and is it easy to install?
: | I have a Dell Dimensions 8300 - went thru the systems list
: and could not
: | spot the motherboard.
: | Pat Miller
: | "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
: | news:%23$ub0pZvEHA.3872@TK2MSFTNGP11.phx.gbl...
: | : Hi Pat,
: | : Has the system always down this? Can you also give some
: specifications on
: | : the motherboard, or provide the manufacturer and model
: number? Blear
: | : Advisor can help you gather this information if you are
: unsure, see
: | : www.belarc.com
: | : Best of Luck,
: | : Rick Rogers, aka "Nutcase" - Microsoft MVP
: | : http://mvp.support.microsoft.com/
: | : Associate Expert - WindowsXP Expert Zone
: | : www.microsoft.com/windowsxp/expertzone
: | : Windows help - www.rickrogers.org
: | : "Pat Miller" <tuaz007@earthlink.net> wrote in message
: | : news:%23mJ$C2VvEHA.4072@TK2MSFTNGP15.phx.gbl...
: | : > Hi Rick,
: | : > Using PC with XP home edition Ver.2002 w/Service Pack
: 2
: | : > Pentium 4CPU 1.80GHz, 1.79 GHz 256 MB of RAM
: | : > HP printer 5650
: | : > When I attempt to print a greeting card I get the
: following message:
: | : > Virtual Memory Minimum is too low.
: | : > Your system is low on virtual memory, windows is
: managing the size of
: | your
: | : > virtual memory paging file. During this process,
: memory requests for
: | some
: | : > application may be denied. Three can happen at this
: point. a) the
: | : > system
: | : > freezes b) anywhere from 20 to 45 minutes the printer
: will print a card
: | : > correctly c) the print is solid black lines.
: | : > My Question is - How do I increase the Virtual memory?
: Do I need to get
: | : > more MB's of memory? Should I complain to the Print
: Shop maker?
: | : > Regards,
: | : > Pat Miller
: | : > "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in
: message
: | : > news:%23TK6$dUvEHA.3872@TK2MSFTNGP11.phx.gbl...
: | : > : Hi Pat,
: | : > : This one is fine, what is your question?
: | : > : Best of Luck,
: | : > : Rick Rogers, aka "Nutcase" - Microsoft MVP
: | : > : http://mvp.support.microsoft.com/
: | : > : Associate Expert - WindowsXP Expert Zone
: | : > : www.microsoft.com/windowsxp/expertzone
: | : > : Windows help - www.rickrogers.org
: | : > : "Pat Miller" <tuaz007@earthlink.net> wrote in
: message
: | : > : news:OO9zGaTvEHA.2804@TK2MSFTNGP14.phx.gbl...
: | : > : > Would someone kindly let me know to which group I
: should my question
: | : > on
: | : > : > virtual memory. Thanks in advance Pat Miller
Reply to Anonymous
Your welcome. BTW, don't worry about having to understand
everything all at once. If you can read and follow
directions, you can learn. Read the article about Virtual
Memory and other articles about printer problems, printer
installations and general troubleshooting, and soon you'll
be able to do all that you need, at least you'll be better
able to describe your problem.
http://www.aumha.org/index.htm
http://www.kellys-korner.com/
http://www.dougknox.com/index2.html
http://www.michaelstevenstech.com/
http://www.winsupersite.com/default.asp
Just browse on these sites and read, soon you'll be as smart
as the rest of us.
news:uR74NLevEHA.1404@TK2MSFTNGP11.phx.gbl...
information, all of
| Pat Miller
in message
the
for
Memory
with
than
drive.
driver"
see a
Printshop
| : software.
| : software.
to
on-line,
type of
supply
want
you
how
or
CPU
if
enough
the
| : computer faster.
| : | Hi Rick,
been
| : unable to print
decided
| : to try to do
is
list
| : and could not
| : | Pat Miller
message
| : | : Hi Pat,
some
| : specifications on
model
| : number? Blear
are
| : unsure, see
| : | : Best of Luck,
message
| : | : > Hi Rick,
Pack
| : 2
| : | your
| : | some
this
| : point. a) the
| : | : > system
printer
| : will print a card
memory?
| : Do I need to get
Print
| : Shop maker?
| : | : > Regards,
| : | : > Pat Miller
| : message
| : | : > : Hi Pat,
| : message
group I
| : | : > on
Miller
Reply to Anonymous
- 0 +
Go to control panel---system---advanced tab--performance setting
button--advanced tab--change button. I have mine set for 3 gigabyte (have 80
gig hd.) Works great.__
> Pat Miller
> : software.
> : software.
> : computer faster.
> : | Hi Rick,
> : unable to print
> : to try to do
> : and could not
> : | Pat Miller
> : | : Hi Pat,
> : specifications on
> : number? Blear
> : unsure, see
> : | : Best of Luck,
> : | : > Hi Rick,
> : 2
> : | your
> : | some
> : point. a) the
> : | : > system
> : will print a card
> : Do I need to get
> : Shop maker?
> : | : > Regards,
> : | : > Pat Miller
> : message
> : | : > : Hi Pat,
> : message
> : | : > on
Reply to Unknown
i guess when you got alot of stuff running at once,like programs running in
the background,you have to turn somethings off like the ones you are not
useing,well check you later i hope this help,bye
Reply to Anonymous
I got the same notice as Pat did, but I don't know what to think now....
It came up when I was running the Norton AV and playing the solitaire
game that came pre-packed with my machine. I'm not loaded up with
"stuff"....I only dl'ed the Nortons Firewall & AV, Ad-Aware, Spybot S &
D, Spywareblaster, and WinPatrol. No pictures, no games, no music. Only
what I've listed here.
The machine is only 3-4 mo. old. I am running WinXP SP1. It as 512MB
Ram, a 120GB HD, and is 2.80GHz. So what could be my problem? Is it
possible the virtual memory shrunk when I didn't need it? I have it set
for the Windows to decide how to adjust it.
And I keep my protection programs updated at least every other day, and
so far they have all come up clean, (except for the usual tracking
cookies, MRU's, and data miners)
I also clear my cookies, temp files, and history at least twice a week.
The only thing I haven't done is pared down my start-up programs because
I'm not sure which ones I need and which ones to disable...
Any help would could give me would be greatly appreciated....Thanks;
Marty
Reply to Anonymous
I have a 100g h/d[main drive], with intial size 720mb and max size 1440mb. I
would like to increase mine but not sure what the amount is for mb to gig.
Can some one help me please? TIA!
Barbara
"Unknown" <Unknown@Somewhere.Kom> wrote in message
news:8Eygd.24849$Qv5.9648@newssvr33.news.prodigy.com...
80
> > Pat Miller
> > : software.
> > : software.
> > : computer faster.
> > : | Hi Rick,
> > : unable to print
> > : to try to do
> > : and could not
> > : | Pat Miller
> > : | : Hi Pat,
> > : specifications on
> > : number? Blear
> > : unsure, see
> > : | : Best of Luck,
> > : | : > Hi Rick,
> > : 2
> > : | your
> > : | some
> > : point. a) the
> > : | : > system
> > : will print a card
> > : Do I need to get
> > : Shop maker?
> > : | : > Regards,
> > : | : > Pat Miller
> > : message
> > : | : > : Hi Pat,
> > : message
> > : | : > on
Reply to Anonymous
1000 MB is 1 GB (purists will speak about powers of 2
[binary numbers] but just keep the powers of 10 in mind.
For info on virtual memory see
http://www.aumha.org/win5/a/xpvm.htm
"Barbara" <star_shine@bellsouth.net> wrote in message
news:359nd.33597$z3.1407@bignews5.bellsouth.net...
max size 1440mb. I
is for mb to gig.
| Barbara
setting
3 gigabyte (have
| 80
information, all of
| > > Pat Miller
wrote in message
by
increasing the
aside) for
it
Memory
boards with
faster than
hard drive.
www.hp.com in
driver
driver"
you
You'll see a
think
Printshop
| > > : software.
| > > : software.
easy to
on-line,
the
type of
memory
and
supply
MB
you want
tell you
and how
software or
computer CPU
well if
enough
makes the
| > > : computer faster.
rights;
overcome.
message
| > > : | Hi Rick,
new
have been
| > > : unable to print
decided
| > > : to try to do
memory is
systems list
| > > : and could not
| > > : | Pat Miller
message
| > > : | : Hi Pat,
give some
| > > : specifications on
model
| > > : number? Blear
you are
| > > : unsure, see
| > > : | : Best of Luck,
message
| > > : | : > Hi Rick,
w/Service Pack
| > > : 2
the
is
| > > : | your
process,
| > > : | some
at this
| > > : point. a) the
| > > : | : > system
printer
| > > : will print a card
memory?
| > > : Do I need to get
Print
| > > : Shop maker?
| > > : | : > Regards,
| > > : | : > Pat Miller
in
| > > : message
| > > : | : > : Hi Pat,
in
| > > : message
group I
| > > : | : > on
Miller
Reply to Anonymous
Thank you Jim. You're a life saver! You guys [and gals!] are great.
Barbara
news:O5YmG6bzEHA.3336@TK2MSFTNGP11.phx.gbl...
> max size 1440mb. I
> is for mb to gig.
> | Barbara
> setting
> 3 gigabyte (have
> | 80
> information, all of
> | > > Pat Miller
> wrote in message
> by
> increasing the
> aside) for
> it
> Memory
> boards with
> faster than
> hard drive.
> www.hp.com in
> driver
> driver"
> you
> You'll see a
> think
> Printshop
> | > > : software.
> | > > : software.
> easy to
> on-line,
> the
> type of
> memory
> and
> supply
> MB
> you want
> tell you
> and how
> software or
> computer CPU
> well if
> enough
> makes the
> | > > : computer faster.
> rights;
> overcome.
> message
> | > > : | Hi Rick,
> new
> have been
> | > > : unable to print
> decided
> | > > : to try to do
> memory is
> systems list
> | > > : and could not
> | > > : | Pat Miller
> message
> | > > : | : Hi Pat,
> give some
> | > > : specifications on
> model
> | > > : number? Blear
> you are
> | > > : unsure, see
> | > > : | : Best of Luck,
> message
> | > > : | : > Hi Rick,
> w/Service Pack
> | > > : 2
> the
> is
> | > > : | your
> process,
> | > > : | some
> at this
> | > > : point. a) the
> | > > : | : > system
> printer
> | > > : will print a card
> memory?
> | > > : Do I need to get
> Print
> | > > : Shop maker?
> | > > : | : > Regards,
> | > > : | : > Pat Miller
> in
> | > > : message
> | > > : | : > : Hi Pat,
> in
> | > > : message
> group I
> | > > : | : > on
> Miller
Reply to Anonymous
Hello Rick and Pat....this is a PS....I use the AVANT BROWSER....(approx one
year now) .....after years with the big blue E....I knew I was in heaven
w/Avant.....fastest, cleanest, easiest......Just an afterthought. Thanks
again for any advice. Auggie
"august finn" wrote:
> Hello Rick and Hello Pat Miller:
> I'm an Ebayer. Today for the 3rd time in about 2-3 weeks the system was
> running slow. I thought it might be related to Pic/Scan Program by Ulead360
> (larger pics for Ebay recently started using 360. scan twice then merge both
> sides of pic, example a record album cover.) The 'you are running low on
> virtual memory window came up. window also reads it will do what it must.
> ebaying was really getting slow (I'm XP Pro w/Cable Modem thus always really
> fast until recently, sluggish getting worse.) I finished my listing signed
> off, went off line checked help and virtual memory. I did try Support
> recommendation: enter Computer Management file thru their window or my
> control panel. I was careful to read all. Bottom-line: reads running 672
> approx and no more was recommended. I entered here and read Pat Miller's
> virtual mem ? I bonded. Please note: my explore tree repeats itself 2, 3,
> and 4 times (I've wondered about this); I did immediately turn off my
> printer and will go to hp.com for scan and help.....is other advice is
> available, thank you, thank you, thank you......Auggie
> "Pat Miller" wrote:
> > Hi Rick,
> > Pat Miller
> > : Hi Pat,
> > : www.belarc.com
> > : Best of Luck,
> > : > Hi Rick,
> > : > HP printer 5650
> > your
> > some
> > : > system
> > : > Regards,
> > : > Pat Miller
> > : > : Hi Pat,
> > : > : Best of Luck,
> > : > on
Reply to Anonymous
"Pat Miller" wrote:
> Hi Rick,
> Pat Miller
> : Hi Pat,
> : www.belarc.com
> : Best of Luck,
> : > Hi Rick,
> : > HP printer 5650
> your
> some
> : > system
> : > Regards,
> : > Pat Miller
> : > : Hi Pat,
> : > : Best of Luck,
> : > on
Reply to Anonymous
see http://www.aumha.org/win5/a/xpvm.htm
"august finn" <augustfinn@discussions.microsoft.com> wrote
in message
news:AFDBB242-91B3-48E1-A427-7603C65AF907@microsoft.com...
was in heaven
Program by Ulead360
are running low on
did try Support
their window or my
reads running 672
read Pat Miller's
other advice is
| > "Pat Miller" wrote:
| > > Hi Rick,
Printer HP 5650 and
list and could not
| > > Pat Miller
message
| > > : Hi Pat,
model number? Blear
are unsure, see
| > > : www.belarc.com
| > > : Best of Luck,
message
| > > : > Hi Rick,
Pack 2
| > > : > HP printer 5650
following message:
| > > your
memory requests for
| > > some
this point. a) the
| > > : > system
Print Shop maker?
| > > : > Regards,
| > > : > Pat Miller
message
| > > : > : Hi Pat,
| > > : > : Best of Luck,
message
| > > : > on
Miller
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > A Virtual Memory Problem
There are 1172 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
