News
CES 2007: 3D gaming, surround sound, and waterproof accessories
Need to transport your Xbox 360 console to a friend's house but don't have a roller suitcase that will fit the system? No problem, Atlantic has you covered with Gaming on Wheels. Want to carry your PlayStation Portable or DS Lite in the pouring rain without damaging it? You can do that, too, with GameSEAL. Read more
Anti-Piracy Measures Via Sound Considered
Piracy of films and recordings are a serious problem. Measures to thwart piracy has ranged from harsh Digital Rights Management schemes to personal searches of movie patrons. However, audio watermark maybe the newest weapon in this war. Read more
Audio supercomputer hidden in your graphics card?
Nvidia's graphic cards may have much more to offer than simply drawing pixels on the screen: A startup company has found a way to translate audio signals into graphics, run them through the graphics card and overcome a common issue of limited audio effect processing performance in computers. Read more
CES 2006: Highlights of Friday's coverage from TG Daily
While thousands stood in line to see Google president Larry Page not announce the "Google PC," we continued to find out some very interesting news last Friday, including looking into how a simple notebook computer can not only achieve high-definition, but surround sound. Read more
Latest Reviews & Articles
Hard Drives, Yesterday And Today: From 500 GB To 1.5 TB
Hard drive capacities have increased in large increments over the last few years, while trends indicate reduced spindle speeds of 5,400 RPM instead of 7,200. We looked at three generations of Samsung hard drives to analyze the performance ramifications. Read more
Best Graphics Cards For The Money: June '09
This month, ATI's new Radeon HD 4770 is missing in action, since online stores are not only unable to keep it in stock, but also de-listing it completely. With violent movements in pricing, though, it'd have been taken off the recommended list anyway. Read more
Editor's Corner: Nvidia’s Ion Revisited, 7.1 Ch. LPCM Fixed
Nvidia's Ion for the do-it-yourselfer launched last month in the form of Zotac's mini-ITX motherboard. Though sexy in principle, the platform had some teething pains right out of the gate. Chris Angelini revisits those issues and uses Ion as a real HTPC. Read more
Core i7 Memory Scaling: From DDR3-800 to DDR3-1600
Do you want a quick Core i7 system, but don’t feel confident sticking to Intel's spec and using the DDR3-1066 memory supported by the processor? We benchmark the most relevant memory speed and timing combinations to check the benefit of going faster. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Games General > Console Gaming > PS3 Sound Problem
PS3 Sound Problem
I have my PS3 connected to my computer via the optical output. The PS3 sound settings are linear PCM and I checked all the boxes in the optical output screen to enable various audio output formats (Dolby Digital 5.1, DTS, etc.). Now when I am in the initial PS3 screen showing all the games on my hard drive, there is sound. However, when I actually play the games there would be no sound. Things get weirder when I play DVD. There is no sound when I play at normal speed but there would be sound when I play at 1.5 x speed. Any idea??
Sponsored Links
I'd only enable the ones you're sure you're going to use and that your system supports. If you chose to enable them all, one setting might take priority over another and function improperly. Does it not auto detect the settings properly?
Reply to Heyyou27
- 0 +
Following your suggestion, I only enabled Dolby 5.1. Still no in-game sound though. I know there is optical sound signal to the computer because I can hear the clicking sounds at the initial XMB screen when I changed the menu.
Reply to aqua08
I'm having the exact same problem. I get audio at normal speed if I use the HDMI throught the tv speakers. How about you? I'm ready to bring it back to Best Buy.
Reply to thedrnailsguy
- 0 +
Same here. Sound through HDMI but not optical. Problem is my TV has only two channel sound. I wanted 5.1 so I connected the PS3 to the computer via optical. Not sure how to correct this!
Reply to aqua08
Not sure you can correct this. If it's not some option that needs to be selected or decelected by the user, it's probably going to have to be fixed by a professional.
The fact it works at 1.5 speed and in the menu tells me the problem is with the PS3. The fact that it works with HDMI at normal speed tells me it's reading the disk ok, so somewhere between the disk and optical out there is a problem. I just don't know if it's software or hardware.
Ok, during a last ditch effort to try and fix the problem before I returned the PS3 I found the solution (At least for me). I'm not sure what audio card you are using but I'm using a Creative Sound Blaster X-Fi "Fatal1ty". Using the Creative console in "entertainment mode" I found the "Digital I/0" options. Be sure the SPDIF input settings are set to "Dolby Digital/DTS SPDIF-In Decode". Mine was set on default before I changed it. Now it is working just fine. I'm not sure how it got changed, I don't believe I changed it. Hope this works for you.
I think the signal in the PS3 menu and at 1.5 speed is not surround and therefor we can hear it. When it switched to a surround signal the setting on the audio card wouldn't decode the signal. Again, I hope this works for you. Let me know how it turns out.
Message edited by thedrnailsguy on 07-09-2008 at 11:31:24 PM
I'm having the same problem and I know for sure it's a problem with the PS3 update. I have been using the my digital optical cable with my ps3 to the surround sound for about a year and have played all kinds of games (including fifa soccer) with digital sound. Then after doing the recent update all of a sudden no sound with fifa soccer. I bought a new game (Assasin's creed) and no sound with that either. There is however sound before I enter the game and I have no trouble with streaming videos. This is definitely a software and not hardware issue...yet again sony's system update messed up something that was working just fine...anyone know anything else about this problem?
Reply to Anonymous
My advice:
If everything works, and its not a critical security update, why update to begin with?
Reply to gamerk316
- 0 +
I have the same sound problem. With my sound problem I have to reset the console or game until finally I have sound. I just recently bought my PS3 and had to update it too. Once the sound works then it finally stays on without problm. I just have to restart it which is very annoying. Can anyone help me find out why. I will stop buying into PS3 if the first console I bought was a defect. Very unhappy so far. I should have stayed with XBOX 360.
Reply to dsmeds
There are 356 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
