My system specs:
Asus P4S8X Motherboard, LAN enabled, Audio/1394 Disabled
Northwood P4 2.8ghz
512mb PC2700 DDR Memory (1 stick)
VisionTek Xtasy GeForce 3 Ti500
SoundBlaster Live!
80GB Maxtor 7200RPM HDD
52x Samsung CD
I'm still trying to narrow down what exactly is causing this, but here's my problem:
Basically, my system is locking up during certain high load applications/games. Playing Morrowind or Everquest it'll lock up within a couple minutes, playing something less graphic intensive such as Half-Life it'll run for anywhere between 30 minutes to 2 hours before it locks up. Rips MP3's all day long and never has a problem though, this baffled me because I thought mp3 ripping was a pretty heavy load activity.
I originally assumed it might be a memory problem, since one of my two sticks was DOA with a similar lockup problem. But, the more I read in this forum, the more I start to think it could be a power issue. Since I started having this problem, I loaded up the Asus Probe 2 software to monitor my stats, and I've noticed that my voltage tends to dip below normal quite regularly. My +12 spends alot of time at 11.8; +5 sticks around 5.105; and +3.3 is almost always at 3.28; And VCore at 1.488. Does this make sense? Is it possible that low voltage during heavy load periods is causing me to lock up?
After reading a bit here I checked my case and the rating seems quite low for what I'm trying to run. (Only 10A on the 12V rail.)
Any input is appreciated. I'll probably end up buying a new power supply from Antec here in the next couple days.
My computers work just fine until I try to "fix" them.
Northwood P4 2.8ghz
SoundBlaster Live!
52x Samsung CD
